Sponsored by: Real Truck
100v inverter dash mod
Old Aug 19, 2018 | 11:38 PM
Shade_Tree_Hack's Avatar
Shade_Tree_Hack
Todays project: adding a 110v power inverter
I have been wondering why there are 4 cup holders in the front driver/passenger area of my f250.
For the most part the 2 cup holders in the dash are redundant and like most cup holders the springs were broke so unless i was putting a 40oz Old English in the holder it was even more useless than before.
I decided to add a power inverter i had laying around. Because why not. I might need to plug in a VCR or something.
I still have some fab to do but the most part this is what i ended up with.
Old Aug 21, 2018 | 07:41 AM
speakerfritz's Avatar
speakerfritz
for electronics you need a pure sine wave inverter
if for lighting a modified sine wave will work
check the watt rating of the inverter vs the power needs of the devices
your cables from the car power system to the inverter needs to be of the right gauge or that will limit power ...typically you need 10 amps of DC per 100 watts of ac.
make sure you put the inverter on the correct sized whitch relay else you could drain your battery if you forget to shut the inverter off.
Old Aug 21, 2018 | 07:50 AM
leadmic's Avatar
leadmic
One other thing when mounting the inverter make sure not to block the hidden compartment under the cup holders.
johnkn
2015 + Expedition & Navigator
Oct 26, 2018 10:39 AM
irishammer
2004 - 2008 F150
Feb 22, 2015 09:06 AM
ccllud
Feb 24, 2013 11:12 PM
bigsnyder
Jun 11, 2009 08:44 PM
01F250marty
Dec 16, 2007 02:48 PM
