Regen issues, jackhammering.
Pull head and upgrade to new design exhaust valves. Reinstall head and everything else. Use the Ford Motorcraft Cetane in your fuel. This dealership was able to eliminate the bucking with the old valve design just by using the Cetane. The Service Manager told me that he recommends it for the new design valves as well.
I asked about reprogramming to use both heads for regen and he said that’s not a viable option. He said all work on any diesel brought into their shop is done by their master tech. I met the master tech before and the guy is legit. The service manager told me when I call in to get my truck maintained and/or serviced, to speak with him directly moving forward. He said his writers are struggling and he doesn’t want me to deal with them anymore.
First, the valves were not redesigned. They simply replace the valves with new ones with no changes.
Second, the calibration update is part of the TSB fix which in fact does change the programming to utilize both banks for the regen fueling instead of just the driver's side only. All current calibrations have that change along with all other various updates.
I was just thinking the same thing
The reflash solved my problem, over 30K miles ago...
If I remember correctly, the TSB only calls for valve replacement if the problem still persist, after the reflash.
I have a feeling when I tell the service manager "because a Ford Truck Enthusiast said so," it comes off as a bit on the weak side.
There wasn't a valve stem clearance issue. There were a few trolls that joined the forum to spread that misinformation and try to cause a panic. They hit this and other Ford truck forums.
With the updated calibrations having the regen fuel on both banks instead of just the driver's side, the jackhammering problem often goes away. If it doesn't, the valve replacement portion of the TSB was to put fresh clean valves in the driver's side head. No head work was performed and the replacement valves were identical to the originals.
The problem is regen fueling on one bank only causes deposit issues.
Unfortunately this isn't the case either.
And be careful about fuel cleaners. Many are alcohol based which Ford explicitly warns against using.
I picked up my truck yesterday afternoon and spoke directly with the mechanic who performed the work. I specifically asked him if the new PCM program directs the regen to occur on both sides. The answer was:
No. The passenger side head has your emissions controls. If that side heats up and the fuel is dumped into it, your dash will light up like a Christmas tree and it'll ruin the emissions system.
I asked the mechanic about the valves he installed and asked him if they were of a different/new design or what. The answer was:
The old valves were replaced with new valves, but the spacing is different.
The mechanic told me he followed the exact Ford repair instructions, including the PCM program update instructions. He did seem a bit unsure about what the actual PCM update does as far as exact specifics. Also, he did specifically ask me if I heard about the regen PCM update switching to both heads from an internet forum.
EDIT:
Just looked over the truck. The radiator fill and overflow bottle is bone dry. I can't see the fluid in the radiator either. There's a bunch of fluids all over the frame from when they pulled the head. It looks like they set the head and all of the parts in the bed and my bedliner is covered with fuel/oil/fluids. I'm rather annoyed right now.
I called the service department yesterday about my low coolant level and was told it probably burped out the air. They said to swing by and they'll fill it up. On my way there to get the coolant topped off, the truck went into regen mode and I tried to reproduce the shuddering / jackhammering effect with zero success. So it appears to be fixed, but I'll try it out on a few more regens before I'm convinced.
So what's your take on the PCM flash keeping the regen mode on one head bank and not going to both due to emissions claim?
Case in point... your coolant didn't "burp" out air. The tech didn't follow proper fill procedures. Not to mention the rest of the mess he made of your truck that you posted here about.
Ford doesn't typically tell dealer technicians what is included or what changes are made with regards to calibration updates.
Also some food for thought..... if the exhaust valves weren't of the correct spec, then why only replace the driver's side? It would mean the passenger's side exhaust valves are also out of spec and would cause problems there too.
