replacing u-joints in axles
Old Sep 23, 2003 | 12:35 PM
TUFFY's Avatar
TUFFY
Hi i'm trying to replace the axle joints in my 1980 f250 i have gotten the left side out but on the right side i can't seem to get the axle out where it goes into the diff. its out of the slip joint so only the little part of the axle is what i cant get out .how do you do this? also how do you tell if you have the 3000 or 3500 pound axles i went to autozone to buy ball joints and they said i needed to know which one i had . thank you dave
Old Sep 23, 2003 | 02:44 PM
bubbaf250's Avatar
bubbaf250
Check this other thread:
https://www.ford-trucks.com/forums/s...hreadid=154841
The lower rated axle is the Dana 44HD. The higher rated axle is the Dana 50.
If your GVW is less than 8500 lbs, you probably have the D44HD (lower rated axle).
The vehicle certification label (sticker in the driver's door jamb) should show the GVW.
Old Sep 23, 2003 | 02:59 PM
SDElwood's Avatar
SDElwood
FTE Remembers
There is a C-Clip on that stubby shaft - you have to pull the diff to get at the C-Clip. In my experience, the u-joint right next to the diff rarely wears out, so I usually leave them alone unless I have other things to do to it like change the fluid, etc.
Old Sep 23, 2003 | 06:35 PM
TUFFY's Avatar
TUFFY
thank you for the help it is much appreciated DAVE
Old Sep 23, 2003 | 06:45 PM
SDElwood's Avatar
SDElwood
FTE Remembers
No problem, Dave. Welcome to FTE - friendly help is what it is all about!
Old Sep 23, 2003 | 08:22 PM
bremen242's Avatar
bremen242
there is an easy way to tell if you have a Dana 44HD or Dana 50. You can't always tell by GVWR. My f-250 truck is 8600, and a Dana 44HD. I think most trucks that are rated 8700+ have Dana 50s (x-cab).
easy way is: look at the u-joints in the axle. if you can't see any clips holding the bearing caps in (they look like the ones on your drive shaft), you have a Dana 44HD. if there are retaining c-clips, its a Dana 50. the Dana 44HD has half-moon shaped clips on the inside of the yoke.
05SuperPooper
Mar 2, 2012 06:51 PM
wiggins
Jul 28, 2011 11:29 AM
rallyracer
Aug 12, 2010 09:59 AM
fordor
Oct 22, 2006 11:41 AM
Kenny
Dec 15, 2003 06:43 PM
