Reverse Switch Location
Old Aug 18, 2018 | 03:55 PM
kcasey87's Avatar
kcasey87
Can anyone tell me where to locate the reverse switch on a 1991 Ford E350 Diesel - automatic
Reverse lights aren't working and want to check/replace switch. I've looked all over... Also am I missing the fuse. I think it may need another 15 amp. I went to put it in but theres nothing there to hold the fuse in....?
Old Aug 18, 2018 | 10:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The switch is on the driver's side of the transmission, where the shift cable attaches to the shift lever. It's the part with the wiring harness attached between the shift lever and the transmission. It's called the Transmission Range Sensor (TRS.) The old names for the part is Manual Lever Position Sensor (MLPS) or Neutral Safety Switch (NSS.)
Old Aug 22, 2018 | 02:27 AM
kcasey87's Avatar
kcasey87
Thank you
Thank you so much. I found it right away after your help! Part ordered thanks again
martin78
Aug 6, 2025 05:00 PM
Bery mykokner
Apr 30, 2019 07:45 AM
Zazoos
30
Oct 3, 2018 06:53 PM
ncdehn
2004 - 2008 F150
Mar 7, 2013 06:02 AM
EagleDakota
Nov 8, 2006 04:16 PM
