Headlights on
Old Aug 17, 2018 | 10:03 PM
philsf150's Avatar
philsf150
Headlights on
I have a 2010 F150 I acquired used about four years ago. It has always had the issue of the headlights coming on anytime the truck is running regardless of what position the switch is in. Any idea why this is happening and how to correct? Thanks!
Old Aug 18, 2018 | 05:56 AM
Tom's Avatar
Tom
It sounds like you have daytime running lamps enabled. I believe they are required by law, and it's been a fleet ordering option for over a decade. Do you know if your truck used to be Canadian or owned by a fleet?
If so, you just need to have that feature turned off in the PCM. I believe there's a way to do it with ForScan, but that's going to take some research to find the correct thing to change. Your dealer could also do it, but they would likely charge an hour's labor for the tech to hook up and make the change.
Old Aug 18, 2018 | 10:18 AM
philsf150's Avatar
philsf150
Thanks Tom. I believe you are right. I found several youtubes and posts saying dealers will not disable it but another solution is to unplug the resistor behind the driver side headlight. It apparently drops the voltage to the low beams from 12V to 10V for the running lamps. With it unplugged, the lamps get 0 volts!! Appears others have had no issues doing this Thx for pointing me in right direction
Old Aug 25, 2018 | 02:00 AM
GaryKip's Avatar
GaryKip
I tried unplugging the resistor wire. They still come on. My truck is a 2011 4X4 XTR, and it was in Canada for a few years..
Old Aug 25, 2018 | 02:11 AM
ford390gashog's Avatar
ford390gashog
The XTR is a Canadian model so it does have DRL. Just disable it with forscan and be done with it.
Kilomanjaro
Feb 23, 2022 12:14 PM
cckemm
Oct 6, 2015 08:42 AM
joners
May 5, 2004 05:20 PM
mxrider131
Jul 14, 2002 09:52 PM
fsmartin
Jul 12, 2002 01:18 PM
