Checking my timing job please help
Old Aug 15, 2018 | 10:12 PM
5.43v's Avatar
5.43v
OK so I took my cam phasers off re did everything and had cylinder 1 at TDC with the valves closed. I put everything all back together, marks all lined up. So is this all correct? So I rotated the crank shaft and none of the marks ever line up again. Please explain, I don't want to button up the cover then have it explode
Old Aug 15, 2018 | 11:52 PM
07F150Lariat5.4's Avatar
07F150Lariat5.4
That is normal. It takes many revs (don't know the exact number of revs) before they line back up again. As long as it was lined up properly initially, then you're set.
Old Aug 16, 2018 | 07:01 PM
redfishtd's Avatar
redfishtd
Its 122 revs not practical to do
You should turn crank by hand 2 full revs clockwise to prove no valve to piston contact . Before you moved her she should have looked like this .
Old Aug 16, 2018 | 09:22 PM
5.43v's Avatar
5.43v
OK fingers crossed I'm going to turn it over tomorrow morning. That's good math to figure out 122. When I took it apart I hardly remember turning the crank until I got the marks to show up on the cam. The chain was all worn out and the guide was broken so I think the chain skipped and the timing was off.. It had stopped running after driving like crap
Old Aug 17, 2018 | 10:17 AM
alloro's Avatar
alloro
It takes something upwards of like 25 revolutions before the timing marks line up again.
KenReb
Modular V10 (6.8l)
Dec 24, 2017 04:30 PM
F500Mike
Mar 27, 2013 10:43 PM
tmm313psu
2004 - 2008 F150
Mar 31, 2010 09:32 AM
big block power
Jan 7, 2003 10:09 PM
d1a2n3e
Sep 21, 2002 12:57 PM
