2017 Lemon
Old Aug 15, 2018 | 09:39 PM
Vezfly's Avatar
Vezfly
2017 Lemon
For the third time today, the oh crap handle on drivers side started leaking water when it rains. The previous two attempts to fix by dealer obviously didn’t work. Curious if anyone else is having this problem, remedies ?
Old Aug 15, 2018 | 09:52 PM
ford390gashog's Avatar
ford390gashog
Do you have the panoramic roof?
Old Aug 16, 2018 | 06:15 AM
TJP249's Avatar
TJP249
Or cab clearance lights. You should also check under driver side flooring for moisture as well. If water is coming down the A pillar from the roof I would have a hard time believing it is stopping at the grab handle. Not sure this issue would qualify for lemon status yet.
Old Aug 16, 2018 | 06:55 AM
Vezfly's Avatar
Vezfly
Yes on panoramic but no cab lights ? 4th time is lemon in my state (LA,). I’m going to check floorboard
Old Aug 16, 2018 | 07:41 AM
senix's Avatar
senix
Drain is clogged somewhere. Try another dealer I think.
Old Aug 16, 2018 | 07:56 AM
Busa 1 Dave's Avatar
Busa 1 Dave
Well the Lemon Law requires specific notification requirements to the manufacturer. It is not as easy as you think. MUST follow the process exactly. I have had two Fords one GM and one MB bought back but you HAVE to follow the EXACTprocess. The written requirement for notification to the manufacturer is in the Owner manual and it includes the specific contact information. Send it certified return receipt vis USPS!
Old Aug 16, 2018 | 08:02 AM
Vezfly's Avatar
Vezfly
Thanks-I’ll let the lawyers do there stuff, I just know it’s getting close at 3 times for same issue in 6 months of ownership. Poor quality control in general on this truck- first ford or truck for that matter. Thanks for your help
Old Aug 16, 2018 | 06:20 PM
cficare's Avatar
cficare
Ford probably learned their lesson, but my 2010 F150 had the same leak and the water was coming from the CHMSL (Center High Mount Signal Light ... AKA: 3rd brake light). They issued a TSB and the replacement part was about $80. I merely replaced the weatherstripping myself. Do you see any discoloration in your headliner above the rear window? Sure sign of a CHMSL leak.
Old Aug 16, 2018 | 07:49 PM
MSDeltasleeper's Avatar
MSDeltasleeper
There is a thread somewhere on here last year about the same leak. Was clogged sunroof drain and multiple people had the same issue.
Old Aug 16, 2018 | 08:39 PM
mciokiewicz's Avatar
mciokiewicz
I have a 2017 F-250 crew cab no moon roof or clearance lights that would leak on the driver side handle when raining and when going through car wash. The fix was the dealer replacing the seal that runs from the front windshield to the back window across the top of the roof. This was replaced around 11,000 miles and hasn't leaked since. 21,000 miles now.
Old Aug 17, 2018 | 01:08 AM
hobbie1's Avatar
hobbie1
Just an FYI - 2014 RAM's do it too. Ask me how I know..... I would look at the seal on CHMSL. FCA fixed the leak and cleaned up my interior. In the case of the RAM this was one of many issues. Our 2018 F250 after 8400 miles - been an outstanding experience.
Old Aug 17, 2018 | 08:29 PM
SCW3's Avatar
SCW3
I had the same problem. Dealer had it for about a month and found that one of the body seams was not welded all the way. I believe it was right above the windshield on the driver side in my case.
Brandon606
Dec 16, 2022 08:47 PM
PatsfanTN
Feb 15, 2019 10:59 AM
FBO Cookie Monster
Dec 9, 2018 11:47 AM
Necronommicon
May 15, 2018 06:37 AM
taylornelms
Sep 27, 2010 12:27 PM
