So far, EVERY truck I have seen on the lots has the cab lights.
Since I will be ordering a truck, and the lights are ....meh..... and a potential place for a water leak, I am considering ordering without them.
Is there a reason or legality for ordering with them?
Thanks.
I like them. Looked at many trucks before I made my decision but honestly I think it sets its apart from the F-150, regardless of the size. Its just a personal preference though.
I passed up a truck on the lot that had everything I wanted to the tee, but no cab lights and 360 camera. I ended up special ordering exactly how I wanted it.
These aren't 18-wheelers... cab lights are for looks. If you're on the fence, I'd recommending passing on them. Why take a perfectly good cab and cut several holes in it, and fill with often poor-fitting plastic housings? Also more to wash and wax around.
You'll see some discuss DOT regs, but bottom line, our trucks don't need them. Any trailer you pull that's of DOT-regulated size to require them, will (likely) have them already...think top corners, widest points at wheel well, etc. That's why Ford has them as an option.
Thanks.
I've special ordered three Superduty trucks over the years (1999, 2010, 2019) and have never ordered the cab lights. I see no use for them and agree that they are just more roof penetrations for potential leaks.
And a dually isn't legally able to tow a longer, wider, or taller trailer...so this strikes me as (legally) unnecessary, despite Ford checking the option box for all dually owners.
(I could be totally wrong, it has been known to happen ...but I'd need to see it in writing to believe it.)
DRW trucks are legally required to have them because they are 96" wide. SRW trucks are 80" so they are optional.
I've ordered my trucks because I could never find SRW trucks on the lot with the cab lights. I like them.
My 2011 had 150,000 miles, My 2015 had almost 100,000 miles and my current 2017 has 36,000 miles
That's over quarter of a million miles with no leaks, no problems with my cab lights.
Like most laws, it's a fun read... but you can just jump down to table 1 on page 310 - "REQUIRED MOTOR VEHICLE LIGHTING EQUIPMENT OTHER THAN HEADLAMPS - Multipurpose Passenger Vehicles, Trucks, Trailers, and Buses, of 80 or More Inches Overall Width". The 5 cab lights are the combination of identification lamps (middle 3) and clearance lamps (outer 2). You'll notice that the law also requires them on the rear... that's why duallys also come with the 3 red lights under the tailgate.
