New Clearance Lights+Rain= Water in my cab!!!
Well I got my clearance lights installed a couple days ago by a body shop. When I got in my truck this afternoon I noticed a little water in my floor mat. I assumed I just hadnt closed my door completely. After a few minutes of driving the light on my gear selector came on ( the "off" light like when you hit the Over drive button on the gear selector.) The light flashes on and off. On my way home after my truck had sat for a few hours I noticed water in my overhead console (lariat). The truck still runs fine and everything acts as it should. But water in my cab is a no no.
My question:
Does the ligth have anythign to do with the water in my cab?
How do I pull the headliner in my truck so i can run some silicone on my lights to keep water out?
Are all of these things becuase of my clearance lights?
My question:
My question:
My question:
to pull the headliner what your going to need to do is remove the sun visors, i think its a total of 6 philips screws...then you will probally have to take out some of the A Pillar molding. i was able to reach my cab lights and install everything by just pulling it past the a pillar but if you feel more comforable doing it without the headliner in then just slowly and carefully pull the rest of the plastic and body clips out and somehow get it out one of the doors....its possible trust me lol.
now would be a good time to put dynomat in the roof while you have the headliner down. it makes a hugeeee difference.
Phil
I just did mine today! I suggest you take out everything they did and do it YOURSELF! (that way you know its done right).
Take out your visors and end clips that hold them, and there are 2 push pins, remove them. Take the covers off your A pillars. Drivers just pulls off. Passenger has 4 10mm bolts holding on OH **** handle and remove that. It will pop out like other side. Loosen your light in the middle so you can pull it down further. Take your head liner away from the rubber on the sides so you dont kink it.
Next you will see 2 screws sticking through and a wire (per each light).
From the top take the covers off and lift the lights off your cab by loostening the screws that hold them down. APPLY SILICONE to the rubber exp around the holes. Fasten it all back down.
APPLY SILICONE over the screws sticking through on the bottom.
Assemble truck again and Vwla Lah! Dry as can be. You could prob just silicone Either side either way if you didnt wanna pull a head liner or didnt wanna take them off the top. If you wanna get crazy you can silicone around the cab lights totally with out pulling anything (USE CLEAR).
Here's my install pics. This may help you in getting to your lights and resealing them.
Clearance Light install pictures from trucks photos on webshots
I would take the truck back to the installer. You paid for a job to be done and it should be done right even if it was cheap. Plus I would make them pay to fix/clean what ever water made it into the truck because you don't want you carpet/ etc to get mold or mildew. As far as the OD light, it might be a water problem or the wire could be chaffed and just happened to fail at the same time as the water getting in.
peckhamjusten
05-31-2008 02:15 PM
