Transmission Question... Shift kit
Old Aug 15, 2018 | 07:04 AM
SLUF681's Avatar
SLUF681
I'm buying a 2001 F250 from my cousin later this week. The truck has right around 200k on it. I'm buying the truck mainly to pull my 32' Copper Canyon 5er. The camper maxes out at 12k. I'll be putting a DP Tuner in it as well. My question is this... Would it be wise to put a shift kit in a transmission with that many miles on it? The intended kit is a transgo tugger.
I rebuilt the transmission several years ago in my 2000 F350 DRW that I had. I put a tugger kit in it and was very pleased with the way it pulled after that.
Thoughts?
Old Aug 15, 2018 | 07:07 AM
Dan V's Avatar
Dan V
Thumbs up on the Tugger. Research your choice on the tuner though.
SLUF681's Avatar
SLUF681
I guess I should also add that the transmission is currently experiencing NO PROBLEMS
Old Aug 15, 2018 | 07:09 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I would like to echo what Dan V has said, especially the tuner choice. Check out 1023 tuning, Gear Head, SDK and the like before committing to the DP setup.
Old Aug 15, 2018 | 07:14 AM
SLUF681's Avatar
SLUF681
So the high mileage doesn't concern you? Also, what's up with DP? I've been out of the game for a while since I sold my dually 5 or 6 years ago. DP was the go-to for 7.3s back then?
Old Aug 15, 2018 | 10:00 AM
good9682's Avatar
good9682
I've got the tugger shift kit and dp tuner in my truck. I've been happy with the set up, pulls my 5er great. I'm not one to mess with changing tunes so DP tuner has worked fine for me.
Old Aug 20, 2018 | 05:01 PM
GEugeneS's Avatar
GEugeneS
I put a DP in mine around 2007, and no problems at all. I especially love the eshaust brake tune. However, I hear the tunes are cheaper elsewhere. Stiil, with any tuner, you should consider installing at least an EGT gauge.
Old Aug 20, 2018 | 05:40 PM
SLUF681's Avatar
SLUF681
Yes sir! The truck has a trans temp gauge in it now. Single pod pillar mount. I plan to change that to either a 3 or 4 gauge pod with EGT, Trans temp, and boost and/or a pressure gauge for my air bags that I intend to put on it for pulling my 5er. Thoughts on a boost gauge? Need it? Don't need it?
Old Aug 20, 2018 | 06:19 PM
GEugeneS's Avatar
GEugeneS
My opinion only: Boost gauge not critical like EGT and Trans Temp, but fun to have and could even help diagnose problems on occasion. As long as you're putting in gauges, I would get it. It's not hard to put in. Also, I like the lower dash gauge mount better than the pillar. Also easier to install gauges than the pillar. You could leave the trans temp on the pillar and get a 3 gauge dash mount, and have room for EGT, Boost, and maybe even fuel pressure? I like ISSPRO, but there are other good gauges out there.
Old Aug 20, 2018 | 07:05 PM
SLUF681's Avatar
SLUF681
I like the idea of easy installation, for sure. The ONLY positive for a pillar mount is it being "in your face", in my opinion. Unfortunately, it makes a blind spot as well. I'm leaning heavily towards a pressure gauge for my airbags, regardless. I'm not going to have a pump, but I'm going to mount a tank under the bed, with a regulator in the cab. There will be at least a gauge for air bag pressure, probably a gauge for tank pressure and bag pressure. That may be the answer to my question, a three gauge under dash mount with 2 air gauges and an EGT.
Old Aug 20, 2018 | 07:14 PM
GEugeneS's Avatar
GEugeneS
I envy your air bag install. Always wanted one.
Old Aug 20, 2018 | 08:06 PM
Supercab's Avatar
Supercab
I have heard nothing but good about the Transgo Tugger shift kit over the years.
DP Tuner sponsors this forum, their tuners were once THE hot one back several years ago-seems pretty much everyone had one.....
I choose to leave my engine completely stock, but wonder whats going on with DP...…
Old Aug 22, 2018 | 06:07 AM
SLUF681's Avatar
SLUF681
I found Airlift 5000 airbags on Amazon for $265, including all mounting hardware. All the rest of the stuff (gauges, regulator, etc) I already have laying around.
We have a 2004 F250 that is used as a rescue/first response vehicle at the fire department. It has a slide out in the bed, and used to be greatly overloaded. We put airbags on it to level it so we didn't spotlight the treetops while driving it. We recently bought a 2006 F550 to replace it. It's only used for pulling our air trailer now, as well as transportation to and from classes, etc. The airbags are great on it. That's what convinced me that they're indispensable
bduke23
1997 - 2003 F150
Sep 8, 2016 06:24 PM
war thunder
Jun 26, 2011 07:57 AM
corwin132
Mar 24, 2011 01:10 PM
dynamis5
2004 - 2008 F150
16
Feb 20, 2007 09:46 PM
