Y block starter
Old Aug 14, 2018 | 10:58 AM
willys392's Avatar
willys392
Y block starter
For all you Y block guru's out there, here is my situation. I have a C2AE ('62) 292 block that I'm bolting to a '56 (F100) bell housing. I'm using a 10" flywheel ('57 car) and I'm trying to put together a starter for it. I have the bendix drive ('57 car) and a new Carquest #3123S) starter. The starter shaft measures 5 3/16" long. When I install the starter drive it appears that there is only about 1/2" between the gear and the end housing. I'm thinking that that isn't enough. Any thoughts?
thanks
Bill
Old Aug 14, 2018 | 07:14 PM
1960fordf350's Avatar
1960fordf350
Did you post this question down in the y block engine section in the other part of the forums? Are you saying the gear is 1/2in behind the flywheel? As long as it dis-engages from the flywheel after cranking you should be OK. Did you have any trouble with transmission fitment?
Old Aug 14, 2018 | 08:18 PM
willys392's Avatar
willys392
It seems that the starter drive is too long for this particular starter shaft. I do believe that I need to change the drive and I'm trying to figure out which one I need. I have 2 part numbers so far, Standard Motor products #SD-595 and SD11.
Old Aug 14, 2018 | 09:03 PM
willys392's Avatar
willys392
Oh and thanks 60Ford for the info on the Y block section. I never knew it was there.
Bill
Tomget
Jan 25, 2019 07:29 PM
matthewq4b
Oct 19, 2016 03:30 PM
matthewq4b
Oct 10, 2016 02:15 PM
MGannaway
Jan 28, 2014 12:04 PM
dondonsmyname
Sep 10, 2010 08:59 PM
