FORscan
Old Aug 14, 2018 | 06:34 AM
150 Beast's Avatar
150 Beast
FORscan
Could someone please direct me to a place to download FORscan?
Old Aug 14, 2018 | 10:34 AM
GlueGuy's Avatar
GlueGuy
https://forscan.org/download.html
Old Aug 14, 2018 | 12:04 PM
150 Beast's Avatar
150 Beast
Originally Posted by GlueGuy
Hey! Thanks!
Old Aug 15, 2018 | 09:22 PM
150 Beast's Avatar
150 Beast
Got Er done!
Now, what do you all set the gain at as a starting point?
Old Aug 16, 2018 | 08:19 AM
storage_man's Avatar
storage_man
Originally Posted by 150 Beast
Got Er done!
Gain ? I don't know what you mean ?
If you know what you want to change, then First is make a backup of all the modules (ie Download to your system). This way if you make a mistake, you can always restore them.
Old Aug 16, 2018 | 09:09 AM
Robbgt's Avatar
Robbgt
Guessing by the OPs other post, I think he's referring to trailer brake controller initial gain setting. It's been a while since I set one up so someone else will need to chime in.
Old Aug 16, 2018 | 09:26 AM
150 Beast's Avatar
150 Beast
bingo!
Too much gain and the trailer tires lock up, too little and the trucks brakes work too hard
Old Aug 16, 2018 | 05:45 PM
JimPaine1's Avatar
JimPaine1
Right in the middle of that
Old Aug 16, 2018 | 06:01 PM
150 Beast's Avatar
150 Beast
That ain’t no help but, I like it.
Old Aug 17, 2018 | 09:23 AM
GlueGuy's Avatar
GlueGuy
As for the TBC, I set the gain at 5 to start. When I tested it in a parking lot, it was a little light, so I bumped it up to 6, and it's been there ever since. As per usual, YMMV.
Old Aug 17, 2018 | 10:18 AM
storage_man
True or false - that setting is saved with the trailer info that you supply ?
And to the OP, don't think Forscan can set the "Gain". I've never seen an entry for it and it isn't a global setting. Ie my question above.
Old Aug 18, 2018 | 03:41 PM
GlueGuy's Avatar
GlueGuy
Don't know, as the trailer we use the brake with is the only trailer we use the brake with. It stays where I set it, and it knows which trailer is which.
I don't set the gain in forscan, I set it with the TBC itself. TBC has little +/- buttons, and pushing one or the other immediately displays on the console where the gain is.
Old Aug 18, 2018 | 07:48 PM
storage_man
Yes that is what I thought. I'm interested if it is stored with the trailer config once setup ?
Old Aug 19, 2018 | 11:10 AM
GlueGuy's Avatar
GlueGuy
You can name your trailers, and we have only two, our TT and a utility trailer. When we hook up, we set the "current trailer" via the console, and the gain on the TBC is where we we left it last time. So I don't know where it's stored. Could be the TBC, could be in the truck's console computer. I suspect the latter.
BorderRanger
2015 - 2020 F150
Mar 22, 2019 08:45 AM
Mil1ion
General Automotive Discussion
19
Nov 4, 2006 04:25 AM
50J03
Mar 26, 2005 12:00 AM
