Another crank no start
Old Aug 13, 2018 | 07:55 PM
Chris_burgan's Avatar
Chris_burgan
Ok, f350 drw 6spd 6.0 driving into work truck runs great towing float trailer and I back into job site shut truck off then 5 min later need to move truck doesn’t start. I did head studs, gaskets, oil cooler, stand pipes, dummy plugs, new heads, blue spring kit and I know some more I can’t remember right now 2 years ago. Then 2500 miles ago I put new injectors in it, another oil cooler, bulletproof diesel rebuilt my ficm, stand pipes, dummy plugs again just because I was there. So back to no start, Icp was 85% and only building 160psi hpo I unhooked icp and still nothing so I changed ipr and that didn’t make a difference. Scanned truck with ids and everything is in sync, all sensors read good except low hpo. And yes truck has oil and low pressure oil. Pulled valve covers and no visible leaks so I put a new hpop. The factory one had 230400 miles on it so seemed like a reasonable thing to go out but no, just put a new one in and still no high pressure oil. What have I missed, this truck has been great for years then pulls this ****.
Old Aug 13, 2018 | 09:16 PM
navistarnut's Avatar
navistarnut
I don't see where you mention if the STC has been updated.
Might be time for an air test before tossing more parts at the problem......you won't see a leak, per se.
It's only reaching 160 psi.......that is a pretty good leak somewhere.
Old Aug 13, 2018 | 09:24 PM
Chris_burgan
Yea I did the new tube that goes from the top of the hpop that snaps onto the branch tubes.
Old Aug 14, 2018 | 09:03 AM
KDAVID1's Avatar
KDAVID1
I didn't see if you did but I'd hit it with an air test. Seems you've changed everything..
Old Aug 15, 2018 | 06:39 PM
mohoneywell's Avatar
mohoneywell
need to pressure check the oil system with air and find your leaks.
How about the nipple cup seals?
Old Aug 16, 2018 | 06:55 PM
bismic's Avatar
bismic
Late 04 or early 04?
95 taco
Sep 25, 2017 03:57 PM
tjustice
May 5, 2017 03:13 PM
Kerly
Sep 17, 2016 01:18 AM
shay9165
Oct 11, 2014 12:26 PM
mackl1
Sep 26, 2010 09:22 PM
