Mod chips/horsepower upgrade chips
I know in our little group (1 F250, 2 F350's, all with 6.0L PSD) of friends this question can lead to some rather heated debate over the campfire, so I only hope we can keep the "flames" down here, as it's hard to cook marshmallows over a forum board!!
I was looking at getting the Torqueforce module since I am looking for some gains in HP & torque, basically a better and stronger running truck but without hotrodding it. The only concerns I have with the Torque force module is the following statement in the description of the Module:
Qoute:
" With a flip of a toggle switch, you can gain from 60 to 110 horsepower which can be felt starting from 1900rpm through redline"
Does this mean that it does nothing below 1900rpm?
I plan on calling some shops soon and visit some Diesel-mechanics to get their view on aftermarket goodies.
I was planning on going with these 3 mods:
1. Module or tuner
2. AFE intake with Proguard 7 filter
3. 4" stainless exhaust
Hopefully we'll get some views from some fellow forum members who have taken this task on already.
Cheers,
Bryce
true, it's hard to get anything were you have very little now !
And most of our 6.0L's have next to nothing below 1500 rpm's !!!
And that fact alone AMAZES me !!!
Come on FORD! MOST diesels are known for their tremendous torque - and down low !!! If I wanted a high reving engine that needed 10,000 rpm's to generate power I would have stayed with my two-cycle motorcycles !!!!
Don't get tme wrong - I like this Ex, it's the BEST travelling vehicle EVER - and I've had NICE motorhomes, too! but Ford left so much more on the table that we should have!
I presume the 'gutlessness' below 1500 rom's or so is due to factors like turbo lag that needs to build boost, slow fueling at those low rpm's, and slow throttle response...
our accelerators are not mechanical and so it seems to me that it's as if the throttle has some 'slack' in it...
I do recall the 7.3L Ex I had before had similar symptoms, but not nearly as pronounced... and the use of the microtuner seemd to really help both the throttle response and the shift performance.
Maybe these modules will do the same thing for the 6.0's !
And thanks for reminding me about the accelerator pedal 'slowness' ! Mine's in the shop now for some 'fine tuning' and I forgot to ask them to look at that !
-cu,
john
But will look into Pauls hp website if that doesn't help...
I just installed after 1 week old and 600 miles the following items and man does it fly. i havent gone racing but will try pretty soon.
1) AFE air intake
2) Magnaflow 4" turbo back with 3" downpipe
3) Edge Power Module 2
4) Catz HID Headlights
The power increase is unbeleivable. i actually dont want to get off the truck.
I just purchased my first Diesel a 2004 F250 Lariat FX4 crew cab SWB with 6.0 and torqshift. it was built in 07/03.
1) AFE air intake
BAD BOYZ... how is that edge module? i have the same questions look at my mods list in my sig and tell me if the module would benefit me as well.. how does the chip feel???
it will spin the tires at take off towing a 10000lb trailer if you dont watch it. I would do it again I love it.Don
The HID lights are true HID and have ballast, igniters, high low controller. They work great. I had to switch since i went from a 2003 navigator with HID's and once you use them you dont want anything different.
As for the module it is excellent. i always keep it in the 50 hp setting since i dont have a pyro meter. i am waiting for the attitude screen from edge to connect.
i went on a highway trip to pick up a trailer and while not hauling i got 19mpg at 70mph.
when towing i had a 38' gooseneck with 30,000 pounds on it and my gas mileage at 70 mph went down to 6mpg.
Don't bash me too hard cause I'm bow-tie guy but ended up getting a Juice/Attitude combo. 6 power settings (0-5) with 5 being 125 horses and 350 ft/tq over stock. Thats haul'en and thats just the Juice. I see that they got 1 for PSD now. I know it's lil more pricy but it's far less expensive then all the pilar mount stuff that the Attitude can do. You can manage the defuel between shifts, boost at low fuel, monitor things like EGT's, Tranny slip, lockout, etc, etc, etc. Edge is a pretty respected company. I'd give'em a look..
