1963 f100 engine swap
The aftermarket FE "390" tube cross member works for a 300 six.
65 up trans mount crossmember should be a bolt on. You'll have to drill holes in the frame for the bolts.
The stock 63 trans mount cross member may or may not clear depending on transmission choice. You may can work around it.
DDeffes
03-05-2015 08:57 PM
jason832
06-06-2014 09:23 PM
Rellim51
18
02-26-2011 11:36 AM
