Bronco II Ford Bronco II
Code 18???
Old Sep 23, 2003 | 08:51 AM
jmcdaniel99's Avatar
jmcdaniel99
Code 18???
I pulled codes and got an 18. My book says it's "Loss of tachometer / IDM circuit failure / SPOUT circuit grounded". So which problem is it and how do I fix it?
1986, 2.9L, 4x4, standard
Thanks
Old Sep 23, 2003 | 10:04 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Code 18???
If the tach. is not working ,fix it.I would check to make that spout wires are ok and that plug is clean and in all the way in. Im not sure what the IDM is/or does so I cant help you there.
What is your truck doing /not doing? That would help us to help you to solve your problem.
Old Sep 23, 2003 | 10:53 AM
jmcdaniel99
Code 18???
Jeff,
B2 runs fine with a/c off. When I turn on the a/c, the engine doesn't throttle-up.
The Tach works at the dashboard. What are spout wires?
Old Sep 23, 2003 | 11:02 AM
Ken00's Avatar
Ken00
Code 18???
Ignition diagnostic monitor, you need to run pinpoint tests N.
Old Sep 23, 2003 | 01:55 PM
jmcdaniel99
Code 18???
Ken,
When you say "run pinpoint tests", does that mean I now need to take it in to a dealer to pinpoint any potential problems?
Can I simply replace the IDM?
Old Sep 23, 2003 | 04:45 PM
mrshorty's Avatar
mrshorty
Code 18???
Pinpoint tests are a series of diagnostic tests that are performed to diagnose a given circuit/component. A good repair manual (Helm, Mitchell, Motor) will have the pinpoint tests in an article called computerized engine controls (about 200 pages). If you don't own a professional manual, you might try going to a public or college library and finding it. Even my small town library has many Mitchell manuals
You could simply replace the IDM, but that may not fix the problem. Best to find the real problem and fix it.
Old Sep 23, 2003 | 07:53 PM
Ken00's Avatar
Ken00
Code 18???
If you would like a copy email me and remind me what you need. racsan99<img src="images/smilies2/an...In Posts!</b>)
Old Sep 24, 2003 | 09:48 AM
jmcdaniel99
Code 18???
Thanks Ken and Mrshorty...
I'll look in our library and get back with you.
jack
Evan_P
Dec 6, 2014 05:22 PM
Diesel_Dirk
Aug 1, 2010 04:48 PM
donny3369
Nov 13, 2008 05:05 PM
jergramkow
Oct 3, 2004 08:12 AM
