lighter removal/replacement
Old Aug 12, 2018 | 11:52 PM
Robin Loveall's Avatar
Robin Loveall
how do I remove the lighter cylinder?
Old Aug 13, 2018 | 05:57 AM
Supercab's Avatar
Supercab
First off welcome to the FTE!!!!
You will have to remove the 2 screws from the radio bezel-they are vertical right above the HVAC controls, then you can gently slip the whole bezel with the radio still installed out enough to remove the lighter cylinder.
Just a note; IF the socket is still "hot" and you don't use the lighter you can do as I did and get a shallow dual USB adaptor and simply plug it in and leave it there for charging your phone.....looks nice and factory installed really....
Old Aug 13, 2018 | 09:39 PM
CBB9M's Avatar
CBB9M
That depends on the model year of your vehicle, which should have been mentioned in your post and ideally, in a signature.
phoneman91
Dec 17, 2013 05:16 PM
koboss1
Sep 26, 2010 02:13 PM
edmundo7
2004 - 2008 F150
Feb 7, 2008 02:26 PM
Dannel
2004 - 2008 F150
13
Dec 26, 2007 12:31 AM
nascaptain99
2004 - 2008 F150
Dec 8, 2004 03:07 PM
