Dead
Old Aug 11, 2018 | 07:21 PM
Andy Shouse's Avatar
Andy Shouse
Dead
I have a 92' f150 4x4 5.8 automatic. I recently went and filled up at the pump and when I started up the engine it died before it idled down. Then smelled the odor of burning wires. I have no spark and the fuel pump isn't coming on. I've change the ignition module and coil and ignition switch...motor still turns over but not crank all fuses are good. ???
Old Aug 11, 2018 | 07:57 PM
sandymane's Avatar
sandymane
Someone else just had the exact same symptoms and issues. One of our valued members, Subford said it was the PMC (computer). It seems the no spark no fuel and the smell was an easy diagnosis . Yes,it was fried. So, I would check that first. Plenty of threads on search on how to do it and what to look for when you pull it. Sandy
Old Aug 11, 2018 | 09:06 PM
My4Fordtrucks's Avatar
My4Fordtrucks
If the motor turns over it is cranking.
Try to retrieve fault codes before you disconnect the battery.
Old Aug 21, 2018 | 04:54 PM
Andy Shouse
Truck fixed. Needed a cpu...2 days later. Want crank again but at least the fuel pump works this tim
Now what's the problem?
Old Aug 21, 2018 | 07:22 PM
Robert Long's Avatar
Robert Long
Sound,s like a bad ground,will kill electronics every time
Old Aug 22, 2018 | 12:52 AM
TooManyMIce's Avatar
TooManyMIce
Open the computer, see what's smoked, then see if you can track down what component or sensor is connected to that circuit. I don't know the ECUs in these well enough to know if there's a common culprit.
Old Aug 22, 2018 | 05:15 AM
Andy Shouse
Truck died again now what ?
Old Aug 22, 2018 | 12:14 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
What repairs have you done since your first post?
Old Aug 22, 2018 | 03:04 PM
Andy Shouse
Repairs
cpu...coil...ignition switch.. Ignition module
Old Aug 22, 2018 | 07:01 PM
Andy Shouse
Dead again
Has fuel pressure and spark
Old Aug 23, 2018 | 06:40 AM
My4Fordtrucks
Just to clarify, you replaced the switch and not lock cylinder?
Old Aug 23, 2018 | 08:29 AM
Andy Shouse
correct switch only . cylinder turns
Old Aug 23, 2018 | 10:43 AM
roboto65's Avatar
roboto65
You say the fuel pumps work. When you turn the key do they run then shutoff or do they run all the time?
Old Aug 23, 2018 | 11:08 AM
Andy Shouse
i can't tell. Let's say they do...ndo...now what
Old Aug 23, 2018 | 02:07 PM
roboto65's Avatar
roboto65
Well your PCM controls the fuel pumps but if you turn the key and you hear the fuel pump continue running then the PCM is bad, most likely, if the fuel pump comes on for a second and then shut off that kinda rules the PCM out but maybe not.
