Alternator Regulator - Request for Advice
My questions are as follows:
With symptoms like this, are the windings, or other internal items, ever found to be a more likely suspect than the regulator?
My thinking is that it seems the bulk of the internal structure is working. It is just a regulation issue. It seems like it is getting enough current to maintain the battery. It just may not be enough for additional load, including ample charging. The regulator seems to be weakened, but not dead. I can just swap the whole thing. But, I can't lie. I am also attracted to a cheaper fix!
So, is there any experienced alternator techs willing to chime in on my tale of woe?
BTW, I do believe it is the 3G 95 Amp variety. Correct me if you disagree. (The pic was taken when I did some other work years ago. It is added for reference.)
P.S. You have some fuses related to the alternator also, I think I would take the alternator off and take it to the store and have them check it to make sure it is bad.
Separately... I have a panel mount digital voltmeter that I am going to wire up until I can determine why the regular dash voltmeter does not fluctuate from the static reading. I now worry about the oil pressure gauge as I don't think I've every seen it change either. (Though, I have never been low on oil.) They are always in the same reading on the meter. Temp and Fuel move as their changes are easily seen.
The switch has continuity to ground any time the oil pressure is below 5lbs. What they did was add a resistor to the gauge cluster circuit board, that when the oil pressure gauge sending unit wire is above ground, the resistor makes the gauge read in the middle. When your oil pressure goes below 5lbs, the oil pressure switch grounds out and the oil pressure gauge reads zero. So my oil pressure gauge reads in the middle or zero, there is no inbetween.
I m not sure if they continued to do this in 98 or not, but if they did it could explain why your gauge never gave any meaningful readings. If you can spot your oil pressure sending unit, you should be able to tell what you have.
Here's the real oil pressure sending unit.
Here's the switch type sending unit.
I am just curious. If the pump function were to somehow fail, I know that damage would likely be certain. However, if the pressure were to drop, and not trigger the reading, how do we know that damage is not already caused by the issue? At what pressure would damage be considered most likely? Could it be 6 PSI? I don't expect you to know or say the answer. But dang! (Is my frustration starting to show?)
As a question, are the sending units interchangeable, to get the functionality to work as expected? Or, is the more required to get it to work?
You can tell when your pressure is really low, the engine lifters will usually start pecking, they are the first to start losing function when the pressure is really low.
Attached is a picture of the original regulator. One of the brushes shows that it was making very little contact. You can see it has just a sliver of fresh wear compared to the other. Incidentally, it was also a lot shorter than the other (1/4" or so). I suspect it wore down faster and just reached it's limit of making contact.
I did not take a picture of the rotor where the brushes make contact. Though, I meant to. It was worn down a little. The wear was even and smooth. While I am not too worried, this wear does make an argument for a rebuilt alternator (that is, as long as the rotor contact is also replaced at rebuild time!). Getting back up and running cheaply is good. It also allows me to plan for an alternator purchase (read as: save up for a good one!).
Info for future reference: The alternator must come out. You cannot replace the regulator while it is still mounted. I do wonder if there is a spec as to the minimum diameter of the rotor contact. This would let me know if I have to be more aggressive in my complete alternator replacement, due to this wear.
Again, Thanks to Dave for his contribution.
