Sponsored by: Real Truck
Carrier Bearings?
Old Aug 11, 2018 | 01:29 AM
DriverD's Avatar
DriverD
Carrier Bearings?
Got some vibration at speed, no noise to speak of.
This is an E450 with a Starlite bus body, about 24' long.
The drive shaft has a front section, a rear section, and a short connector between those with two carrier bearings.
I crawled under to inspect. No play in either U-joint, but there is some slop in the front carrier bearing.
Q: Can I replace the carrier bearings without jacking up the vehicle? Seems to me there's enough room to work under there, is there any reason the wheels must be off the ground?
Old Aug 11, 2018 | 07:41 AM
DogRidesInBack's Avatar
DogRidesInBack
Ca you post pics? Partly to check the parts naming.
Carrier bearings usually make noise when starting out from a stop. But mine was so far gone when I got the truck that the vibration and noise happened at all speeds.
Chock all wheels if servicing anything in the driveline, but no particular reason to have the wheels off the ground *as long as everything still lines up* when putting it back together.
Old Aug 11, 2018 | 08:47 AM
Desert Don's Avatar
Desert Don
Did you buy the unit new? If not, look at the drive line and compare the alignment of all the u-joints. They may be out of proper phase. Very possible if someone did some work on the driveshaft previously.
https://www.drivelinesnw.com/part-tr...lysis/phasing/
Old Aug 11, 2018 | 03:43 PM
rprice's Avatar
rprice
Before you get really involved with the rear axle, I would carefully check all of your tires for blisters/separation/axial and lateral runout. I had a similar problem about 2 months ago with vibration at about 60 mph with no noise; thought it was U-joints so checked those carefully and every thing was fine. Also, the rear axle pinion will have some rotational play in it due to backlash between the pinion and ring gear and clearance between the carrier and axle splines. Turned out I had a bad tire separation on the right rear, but I could only see it when I put the rear axle up on jack stands and drove the vehicle at a SLOW speed, then it became obvious.
Good Luck.
dog2580
1997 - 2003 F150
Jan 10, 2012 10:07 AM
dfboothe
Sep 20, 2010 09:28 PM
muddingmcdude
17
May 10, 2010 04:10 PM
87_gt
Apr 24, 2009 08:25 PM
4mil
Offroad & 4x4
Jun 16, 2004 12:53 AM
