911 assist in Sync
Old Aug 10, 2018 | 05:21 PM
cadent49's Avatar
cadent49
911 assist in Sync
My truck is a '18 F350 with Nav and Sync 3.-- I can not keep the 911 assist to retain the numbers I put in. Called Ford customer support and they knew less about than I do, and that isn't saying much.
Old Aug 10, 2018 | 07:22 PM
ford390gashog's Avatar
ford390gashog
The 911 assist just calls 911 in the event of a detected crash.
Old Aug 10, 2018 | 07:48 PM
cadent49's Avatar
cadent49
Thanks, i understand. I'm questioning as to why it does not retain the number I put in there to contact in the event of an issue requiring help. At start up, every time the number I store is not stored,
Old Aug 11, 2018 | 01:47 AM
wildcard30's Avatar
wildcard30
Because it will only call 911. It will not call any other phone number. The feature is either on or off. If off no call to 911 in case of accident, if on it will call 911.
Selecting any other phone number to call is not an option. The discription of how it works is here.
https://owner.ford.com/support/how-t...with-sync.html
I understand you may be able to input an ICE speed dial number, but the system will only call 911 in an accident.
Looking at Ford’s description of how it works for the ICE numbers, the pictures are for an older version of sync. These pictures are of the system I have in my 2013 Fusion.
This could be another case of a function that does not work in the new version vs an older version. It would not be the first time Ford’s programmers left the hooks for a software function that actually does not work correctly in the sync system.
Or perhaps it worked in an earlier version of sync, say 2.3, but is now broken in 3.0.
i never tried to use this function in my Fusion or F-250, but I’ll see if I can input the ICE numbers in both and check them after a key cycle.
UPDATE: I added ICE contacts to both my older sync system and sync 3 in my F-250. The contacts where there after the key cycle. So it works as it should, for me anyway.
To the OP, perhaps it’s your phone or the way sync down loads your contacts. The key must be in the on, not ACC, position in order to access the ICE contacts. Also, what version of sync are you running? My truck is running 3.0. I have iPhone 6s running IOS 11.4
These contacts can only be dialed from the 911 assist screen by pressing the ICE contact button for the one you want to dial. They are not called when the 911 assist is activated.
Old Aug 11, 2018 | 06:20 AM
K A M's Avatar
K A M
It only dials 911 when air bags are deployed. You cannot program phone numbers to it.
Pioneer1
Jan 24, 2018 10:11 AM
Sleepyguy
Mar 16, 2017 06:12 PM
kd460
Escape & Escape Hybrid
Jul 29, 2016 08:24 PM
RAPR
6.7L Power Stroke Diesel
Mar 16, 2012 06:09 AM
kswebb1
13
Feb 10, 2010 06:58 AM
