Remote Start & Check Engine Light
Old Aug 9, 2018 | 07:32 PM
Les C's Avatar
Les C
I have the 2015 Ford F350 Crew Cab. I was on vacation for about a week. I came back today, had to use my truck, but the remote start would not work and the check engine light is on.
I know this happened once before and my question was answered in the forum. I just forgot what to do.
Old Aug 9, 2018 | 07:49 PM
Iowa Ford's Avatar
Iowa Ford
Remote start won"t work with a check engine light on.
Read the codes and get them cleared.
Old Aug 10, 2018 | 07:42 AM
my_crib_too's Avatar
my_crib_too
Call dealer and make an appointment to get the check engine light trouble corrected.
Bruce
Old Aug 10, 2018 | 07:55 AM
seville009's Avatar
seville009
Old Aug 10, 2018 | 08:20 AM
Les C's Avatar
Les C
The check engine light went out and now the remote start works fine. I think it is haunted.
Old Aug 10, 2018 | 08:40 AM
schlepprock250's Avatar
schlepprock250
Just food for thought but remote start won't work if the hood is open either.
Old Aug 10, 2018 | 09:53 AM
jav_eee's Avatar
jav_eee
It's probably the usual exhaust gas recirc sensor thing or whatever it is. Mine trips every once in a while when I remote start it. It goes away after a few starts. I think there's a TSB on it. I haven't taken mine in to get looked at.
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
If your check engine light was on a code was generated. Some issues that generate the check engine light can result in the check engine light to going out after driving the truck (or car). However the code that was generated will be stored. You should find out what code was generated and what causes that code to be generated. It could be a warning of a problem that will bite you harder at a later date
Old Aug 10, 2018 | 01:25 PM
kper05's Avatar
kper05
You still need to check the codes. For example, when my #5 fuel injector was failing, the code was always active and would return after clearing but the CEL wasn't always on.
JEB63
Jan 26, 2019 05:04 PM
Les C
6.7L Power Stroke Diesel
Jun 5, 2018 08:50 AM
Esoj
Apr 17, 2017 03:53 PM
upnorthman
Electrical Systems/Wiring
Jul 7, 2010 12:01 AM
bohiaa
Sep 29, 2009 06:34 PM
