Factory shock sensor?
Old Aug 9, 2018 | 02:53 PM
XPerties's Avatar
XPerties
So I searched but you could imagine keyword "shock" would return a ton of results.
I just purchased my first 18 F250 6.7DSL and realized I have perimeter..aka motion sensor with factory alarm but from what I understand there is no shock sensor? If that's correct does anyone know of a DIY for 17 and up to install a aftermarket shock sensor?
Much appreciated.
Old Aug 10, 2018 | 08:29 AM
shorton's Avatar
shorton
I'd be interested in a Ford part number for 2018 shock sensor as well. Thx!
Old Aug 10, 2018 | 05:27 PM
ymsmiley's Avatar
ymsmiley
Curious too. I'd added one to my previous F150 but I'm sure theres a new p/n
Old Aug 10, 2018 | 09:48 PM
kho6658's Avatar
kho6658
FT4Z-19A361-A this is what I installed on my 2017. I also bought the LED light.DM5Z-19D596-A
Vehicle Security System, Optional LED Kit
Old Aug 11, 2018 | 11:16 AM
XPerties's Avatar
XPerties
I was actually talking about adding a shock sensor module from aftermarket company for like $30 bucks.
This guy has several videos and in one he adds stinger dual shock sensor. I know it's probably a simple tap into certain wires.
Old Aug 11, 2018 | 12:10 PM
kho6658's Avatar
kho6658
I looked at the same when I first started looking. I called and talked to the guy about the install which sounded simple. I just wasn't comfortable cutting into the factory wiring harness. So went with the plugin unit. It was 5-minute install.
Old Aug 11, 2018 | 03:06 PM
XPerties's Avatar
XPerties
So how good is the stock shock sensor? Bag on window or side of truck and it sets it off? Adjustable sensitivity?
Old Aug 11, 2018 | 03:21 PM
kho6658's Avatar
kho6658
Yes, a small hit to the window or door and it will blow the horn once to let you know. Hit it again or hit it hard enough and it will go off. There is a sensitivity adjustment also.
Flynman
Jul 28, 2020 08:49 PM
Sleepyguy
Aug 12, 2019 03:55 PM
Mr.JP
Jul 29, 2004 08:24 AM
hotbbb
Electrical Systems/Wiring
May 1, 2004 10:11 PM
