Sponsored by: Real Truck
Bed Crane/Jack
Old Aug 9, 2018 | 05:12 AM
dzdiggin'dude's Avatar
dzdiggin'dude
Bed Crane/Jack
Anybody have a bed crane? The type that bolts in the back corner of box. Did you have to reinforce the box or just bolt in. What brands? Thanks.
Old Aug 9, 2018 | 08:11 AM
finn's Avatar
finn
I’ve looked into them for my own truck. There’s really nothing substantial to bolt them to without fabricating some sort of structure under the bed floor to transfer the load to the frame.
Most of the trucks I see running them are older, and the beds are tweaked to some extent, so I passed on installing one, even on my old plow truck.
the lift is only part of the project. The substructure is the other.
Old Aug 9, 2018 | 08:39 AM
FractureCritical's Avatar
FractureCritical
there are models that fold-away into an integrated rear bumper. Might be easier to use and install
Old Aug 9, 2018 | 08:45 AM
jimzdat's Avatar
jimzdat
I had one of them in my old 83 1 ton - had to cobble up supports down to the frame in order to actually be able to lift anything.
I'd never bother with one again if it were up to me
Old Aug 9, 2018 | 10:30 AM
puppyf250's Avatar
puppyf250
How much weight are you looking to lift? Reason I ask is when we go hunting, we have a "game lift" that goes into the receiver hitch. We use it to lift and hang deer, elk, etc. Also handy for lifting the generator into the bed. However I believe it is only rated for 300 pounds. If you are lifting less than that, this might be an easier solution for you. And you can remove and store it when not in use. Found it at Cabelas. If you need more lifting capacity, then this might not help you.
Old Aug 9, 2018 | 12:03 PM
Mike1's Avatar
Mike1
If you're lifting heavy loads I'd probably get something like this, if you don't want to modify your bed to frame supports.
Amazon Amazon
Old Aug 9, 2018 | 07:06 PM
dzdiggin'dude
Did look into ones that go in the receiver hitch but like the way the other ones tuck in the corner when not used. Was hoping someone had good luck with one. Doesn't sound like it. Thanks for input. Haven't seen one that folds into bumper. Have a brand I can search?
Old Aug 9, 2018 | 07:11 PM
Mike1's Avatar
Mike1
I'm sure some have figured ways to mount them but I have only seen them work well on service trucks that have diamond plate bedding.
Bronco Billy
Large Truck
Oct 17, 2015 11:33 AM
Flaflathead
Nov 22, 2005 06:49 PM
53 4 me
Oct 17, 2004 11:05 PM
live2hunt
All Things Towing
Mar 16, 2004 11:37 AM
