Manually lift PTO hydraulic bed? 1967 C600
The old farm truck is a 1967 C600, has PTO hydraulics, and long single-stage cylinders on the outsides of the frame rails to lift the 18' bed. The truck hasn't run in a hand-full of years; the headboard has a catwalk which extends forward just enough as to not allow the cab to be tilted...
So, I'd like to lift the bed manually, perhaps only 6-10" or so. Might a handyman jack lift the bed, or will I likely damage something? Should the control valve be put in a 'half way' position to let the fluid flow freely? or?
Thanks for the thoughts, Joe
I would put the control in the float position so fluid can flow. Then depending on if you could put a piece of steel beam or channel across the frame rails, you could put a jack between that and a crossmember near the front center of the bed. If not, I would use wood blocking on the ground to position the jack under that bed crossmember. I would use at least a 12 ton hydraulic jack. After the bed was raised enough I would use blocking between the frame and the bed to hold it in position and not rely on the jack to hold it.
Good luck and do it safely.
kythri
02-10-2013 11:21 PM
f100jim
08-11-2010 02:36 PM
Timgeorgi
16
04-13-2006 03:19 PM
Djzone18
05-06-2004 12:50 AM
