Exhaust leak fix help
any type of JB or liquid metal is going to be an Epoxy base.. So it will burn at 400 degrees. They use to make a "furnace cement" that was more like thin-set or mortar mix.. that might work better..... Normally on exhaust systems you need to put a circular clamp over the hole, or replace the pipe.
welder79
03-19-2009 12:14 AM
