Torque it down
Old Aug 10, 2018 | 08:46 PM
82_F100_300Six's Avatar
82_F100_300Six
Thanks RR
Old Aug 10, 2018 | 10:06 PM
matthewq4b's Avatar
matthewq4b
Originally Posted by 82_F100_300Six
Do you guys torque stuff dry or put oil on it?
The torque settings you see in the manual you see are for clean and dry threads and are reduced by 10% with lightly oil threads, unless otherwise noted.
Old Aug 10, 2018 | 10:15 PM
82_F100_300Six
Thanks Matthew I was wondering if there was a correction factor for lubed threads
Old Aug 11, 2018 | 12:14 AM
matthewq4b's Avatar
matthewq4b
No lubed, lightly oiled. Thread lubricant or other thread lubricants and anti seizes may require a reduction of up to 30% or even more. The manufacturer should have an average torque reduction percent for their product. If they don't have it then I would use a product that does.
Old Aug 17, 2018 | 10:46 AM
Onions.n.Butter's Avatar
Onions.n.Butter
Precision Instruments split beam. Very similar to the Snap-on, Identical to the Mac. Been using it every day for the last 5 years, still accurate and works like new. I've got both the 3/8 and 1/2, and a Gearwrench 1/4 which is ok, but it's got the twist handle which sucks for the bigger ones
Amazon Amazon
Old Oct 20, 2018 | 06:19 AM
DikiesGarage's Avatar
DikiesGarage
Not sure if its just around here in West Central Fl or not, but if you have a better quality wrench, socket, or ratchet, like craftsman, and above, We can
take them to the Home Depot and they will warranty them with one of there Husky branded tools.
Old Oct 20, 2018 | 07:37 AM
Tedster9's Avatar
Tedster9
Originally Posted by kr98664
​​​​​​It's easy enough to check for yourself. You only need a tape measure, some known weights, and some math. This video explains it fairly well:
https://m.youtube.com/watch?v=uFDUsUEQrL0
For a known weight, don't trust a bathroom scale. A gallon of water weighs 8 lbs. right on the nose.
A gallon of water weighs 8.34 pounds
Old Oct 20, 2018 | 08:37 AM
matthewq4b's Avatar
matthewq4b
[QUOTE=Tedster9;18259799]
A U.S or Wine Gallon of water weighs 8.34 lbs or 8 troy pounds of wine . A proper gallon (Imperial) of water is exactly 10 Lbs at 62°F
CBeav
Nov 16, 2018 07:30 AM
82_F100_300Six
6.2L V8
Jun 18, 2018 01:20 PM
Tugly
15
May 21, 2016 02:48 PM
blmw
Ford Truck Parts for Sale
Nov 5, 2012 10:23 AM
Stewart_H
Jul 10, 2012 09:47 AM
