6.2L V8 Discuss the 6.2L V8
Engine Code P06B6
Old Aug 6, 2018 | 02:09 PM
SCarolina's Avatar
SCarolina
Engine Code P06B6
I recently bought a 2015 F250 to replace my higher mileage 2012, wanted to keep that body style. I bought it with the check engine light on and the owner showed me a clean Carfax and a print out of a local dealer’s code reading saying the light is on due to a misfire code, one of the coils are bad. So I buy it and drive it to two part stores to give me code P06B6 (Internal Control Module Knock Sensor Processor). I work on the road so I had to leave it at the ford dealer this week and they can’t look at it until Wednesday. I am very nervous about this code and any info I can get from y’all about it will be highly appreciated. The engine light isn’t on all the time so I’m praying and hoping it’s minor and that I didn’t just buy a ticking time bomb.
Old Aug 6, 2018 | 02:21 PM
Chuck's First Ford's Avatar
Chuck's First Ford
Common Problems That Trigger the P06B6 Code
  • Powertrain Control Module (PCM) failure
  • Wiring issue
do not purchase a vehicle with a check engine light LIT...
if it was an easy fix.. the seller would have had it fixed...
Old Jan 22, 2019 | 12:34 AM
Corey Moore's Avatar
Corey Moore
What did you did to fix your p06b6 code? I have the same problem on my 2012
Old Jan 22, 2019 | 03:14 AM
SCarolina's Avatar
SCarolina
It turns out I had three bad coils. Had the dealer replace them and the code hasn’t been back since, good luck.
Old Oct 25, 2019 | 09:39 PM
UsmcParm's Avatar
UsmcParm
what did that end up running you?
Old Aug 28, 2020 | 07:03 PM
Ishka Bibble's Avatar
Ishka Bibble
I had the same problem. It was one of the coils. Arcing from the spark plug. I replaced the coil and the check engine light and code went away. Been over a month now.
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
2001 5.4 Supercrew
1997 - 2003 F150
Dec 8, 2010 11:09 PM
bvbunky195
Escape & Escape Hybrid
Apr 30, 2010 07:32 PM
batch
1983 - 2012 Ranger & B-Series
Jan 1, 2002 02:21 PM
