Sponsored by: Real Truck
Coolant
Old Aug 5, 2018 | 03:48 PM
Silver_6.7's Avatar
Silver_6.7
Coolant
so my coolant level seemed a tad low A couple of weeks ago, so I topped It off. I’ve got about 54,xxx miles so I figured It to be in the norm. I checked It again earlier this week and it’s low again. I’ve got the dpf and stock exhaust still on the truck so I figured I wouldnt See any smoke it was burning from the coolant leak if there is one. Idk if this is true but what does anyone think it could be low from? Still under warranty I’m thinking about taking it in to get pressure tested. yay, or neigh?
Old Aug 5, 2018 | 04:51 PM
Just Strokin's Avatar
Just Strokin
Yes, take it in have them pressure test the coolant system. There might be engine or some other reason for the coolant loss. Try the engine angle first since you outside the 3/36 warranty period.
Old Aug 6, 2018 | 11:13 AM
EDC8008's Avatar
EDC8008
What year? How low is low? Are you staying above the low mark on the Degas Tank?
Could be it’s a cap, the springs will weaken over time. We used to carry several on the service trucks as they would start to not hold pressure after 2 or 3 years and will cause a slow slight loss. Most people don’t realize there are 2 on these rigs.
Also there have been known issues with the tanks on the radiator coming lose and starting to leak. My 2014 did at 50K so new radiator and hoses then. My 2008 had issues with the upper hose that did the radiator that time also. The new style radiators with the plastic tanks crimped to aluminum radiators just never sounded good to me. Fortunately these were all covered under warranty.
I’ve also seen water pump seals start to leak, heater cores, a number hoses.
Number 1 is pressure test the cooling system and the caps before anything else. It’s odds on gonna be pretty cheap as long as the routine maintenance has been kept up.
Old Aug 6, 2018 | 11:20 AM
Silver_6.7's Avatar
Silver_6.7
It’s a 2016 I chnage The oil every 5,000 miles whether I need It or not. As in low I mean Barely under the low mark on the tank like where the clear meets the black but I never Realized it because I park On an incline faced down in my driveway when I check Everything weekly but for some reason something told me to check it before I was Leaving work on flat Ground.
Old Aug 6, 2018 | 05:21 PM
EDC8008's Avatar
EDC8008
Ok so like you think slow leak, pressure test is step one. Should be able to get a pressure tester to use from like autozone, oriely’s or such, no need to buy but be sure and get the right adapters for the Ford trucks.
I’m still thinking it’s probably the radiator caps, you’ll need those 2 cap adapters but if you test and no leaks that pretty well says they’re the problem. Anytime I do cooling system work now I just go ahead and replace, cheap insurance.
Old Aug 7, 2018 | 05:25 AM
senix's Avatar
senix
I'd take a look through the drivers side wheel well and look near the petcock for evidence of a leak. I agree, the cap is just a few bucks to replace. So look at that first for any evidence of a leak.
Old Aug 7, 2018 | 12:26 PM
Batman7777's Avatar
Batman7777
Please let us know what you find to be the cause.
jmuenchow
Apr 12, 2018 06:13 PM
Becca_78
Aerostar
Jun 8, 2008 03:28 PM
Trailblazed
15
Mar 29, 2008 10:51 PM
dorsetmerv
Oct 6, 2005 12:56 AM
dorsetmerv
Oct 5, 2005 11:06 AM
