05 Expy air suspension line diagram
Does anybody have a diagram onhow the air lines are routed? Also a pinout of the front solenoid connectors?
I believe I have two problems, the compressor runs but seems to have very low pressure coming out of the dryer with the long disconnect .
I was able to hold an air gun nozzle from shop air to the line that connects to the dryer,but only the rear inflated. I was not able to inflate the front bags, I'm assuming there is a T fitting that feeds the front bags? Both height sensors are connected .
Thanks
Thanks
I'm trying to isolate each spring to check for leaks,I figure the best way without the scan tool is to apply 12v to each solenoid from the module harness. Assuming it is not buried inside the dash. Now the compressor is not kicking on so I also want to make sure it's getting power .
Thanks again.
Ok. I seemed to have narrowed my issue down. Some reason the old air compressor,which seemingly was replaced before( had suncore lable on bottom) would run but not put out enough pressure to inflate the bags.
Replaced the old one with a used OEM unit and had 3 corners inflated. The driver side, which did not inflate had a broken height sensor.
I installed another sensor that I had laying around that came off the passenger side of another vehicle but no luck.
Are the height sensors directional? ( I.e. Left,Right,Rear) Or did I happen to have a bad sensor?
I assume Ford wouldn't spend the extra money not having universal height sensors,but I've been wrong before.
audichopper
1997-2006 Expedition & Navigator
15
06-12-2017 10:03 AM
borcht warrior
02-06-2011 10:13 PM
