03 Navigator Leaking Water
Old Sep 27, 2018 | 06:10 AM
Ty5786's Avatar
Ty5786
I own a 2003 Navigator with sunroof. I noticed that this past week when it has rained my car starts to have a slow water leak through the front driver side visor. I have read post here about the drain pans but I have not seen anyone actually say their vehicle is leaking through the visor. It is leaking on the hard plastic part of the visor right before the soft material actual starts. Can anyone help with me this before I decide to take it to a shop and have them look at it?
Old Sep 27, 2018 | 09:53 AM
alloro's Avatar
alloro
The sunroof drain pans could be overflowing if the drain tube or tubes are clogged.
Old Sep 27, 2018 | 09:54 AM
Ty5786's Avatar
Ty5786
thank you. I’m going to take it a look at it this evening. Thanks very much.
Old Sep 27, 2018 | 10:05 AM
alloro's Avatar
alloro
There are 4 drains, one at each corner. The drain hoses then runs down it's nearest roof pillar. I believe if you remove the pillar you can see the drain hose and maybe a coupling. If there is a coupling this is a good place to take it apart and blow low pressure compressed air through in both directions.
MrFord619
Dec 24, 2023 10:06 AM
WAID
May 2, 2019 03:20 PM
Misky6.0
Aug 11, 2017 11:01 AM
btm991
Mar 19, 2011 08:14 AM
murphy_r
Nov 17, 2006 04:08 PM
