glow plug relay issue
Old Aug 3, 2018 | 10:37 PM
lvhdude's Avatar
lvhdude
4wd Low
I have a 1992 F-250 with a 7.3 diesel. I replaced the engine with a good used motor, and now the glow plug relay just clicks in and out. Will not turn on the glow plugs. All the fuses are good, batteries are hot, fires right up with a little WD, Any ideas on what is causing that relay to chatter? Thanks in advance.
Old Aug 4, 2018 | 06:08 AM
Dieselamour's Avatar
Dieselamour
Have you checked the individual GPS when they are isolated from the circuit? You can ohm them out for "best health" diagnostics or use a test light. I seem to remember a few posts on here that one of our two relay designs short cycles when 2, 3, or more GPS go bad.
Old Aug 4, 2018 | 10:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
my bet is a bad connection on the controller, more specifically, a bad ground.
Old Aug 4, 2018 | 10:37 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Yeah I had this happen on my F450 a couple months ago.The easiest and likely best thing to do anyway,was run a devoted ground wire from the battery right over to the controller.Took just a few mins and now it's got a devoted ground so it wont have the issue again.If it ever happens to my other truck,I'll do the same.
Codeman894
Sep 28, 2017 08:59 AM
jtorrez22
13
Jul 10, 2015 05:14 AM
Ravenous Weasel
Jan 17, 2012 08:30 AM
Tom Callan
Apr 4, 2011 06:16 PM
mpbpulaski
Oct 17, 2004 10:28 AM
