Sponsored by: Real Truck
Does not start
Old Aug 3, 2018 | 07:06 PM
duallydondon's Avatar
duallydondon
Does not start
Have a 2015 SuperDuty with 6.2 engine,,,turn the key on to start , the gauges light up but nothing happens,, no clicking nothing,,happened once before and it did start after 40 minutes or so,,,battery is fully charged,,terminals clean etc,,what is there to check next???
Old Aug 4, 2018 | 03:15 PM
seville009's Avatar
seville009
Starter maybe? Battery cables tight?
Old Aug 4, 2018 | 04:00 PM
duallydondon
Battery cables tight, terminals cleaned,,truck has only 8200 miles on it
Old Aug 4, 2018 | 04:20 PM
seville009's Avatar
seville009
Looks like it’s still under warranty; if so, take it to the dealer
Old Aug 4, 2018 | 04:24 PM
Djosbun's Avatar
Djosbun
Take it out of park then put it back in to park.
Try and start it.
— Dave
Old Aug 4, 2018 | 05:02 PM
duallydondon
tried moving lever out of park several times,,time wise it is out of warranty
Old Aug 4, 2018 | 05:18 PM
seville009's Avatar
seville009
Do you have the factory remote start? If you do, does it have the same problem when remote starting? If it starts ok with the remote start, then maybe it’s something in the key ignition
Old Aug 4, 2018 | 05:21 PM
duallydondon
no do not have remote start
Old Aug 4, 2018 | 08:14 PM
Evan_P's Avatar
Evan_P
Is the theft light flashing in the instrument cluster with the key on?
Old Aug 5, 2018 | 11:25 AM
duallydondon
no theft light does not flash with key on
Old Aug 5, 2018 | 12:13 PM
Juneaudave's Avatar
Juneaudave
Bummer on the warranty, If the engine won't start, you would think that would be covered under the 5 yr/60000 mile powertrain warranty. Anyway, while I'm taking wild guesses, maybe check for a fuse or relay? Fuse 89 (40 amp starter fuse) under the hood, or relay 48 run/start.
Old Aug 5, 2018 | 12:48 PM
duallydondon
I got the 3 year 36,000 mile warranty,,,will check the fuse and relay ,,thank you
Old Aug 6, 2018 | 05:24 PM
burnthelight88's Avatar
burnthelight88
3/36,000 is bumper to bumper. Wouldn't help if say it is ignition switch related. But you should have a 5/60,000 mile powertrain warranty in the event that its an engine problem.
Old Aug 6, 2018 | 05:42 PM
duallydondon
Crisis over,,turned out a relay had intermittent issue,,,running with no issues
Pilotenvy
2009 - 2014 F150
Apr 11, 2018 10:51 PM
cwalsh540
1997 - 2003 F150
Jan 19, 2018 07:43 PM
LaReko
1997 - 2003 F150
Jun 20, 2012 09:35 PM
prohopwer
Nov 21, 2006 08:19 PM
DirtSquirt
1983 - 2012 Ranger & B-Series
Nov 7, 2005 10:42 PM
