Sorry drum brake,(primary sec shoe) ?
I'm sorry guys, I know there have been a few recent and many old threads about drum brakes. I have read all I could find, but still have a question about primary and secondary shoes. Which has the longer lining, the primary or the secondary ( I think there is often conflicting thoughts on terminology as to which is which) , and which goes towards the front of the truck (longer or shorter linings)? My 48 F1 is now stock front brakes, and the rear has a 70 F150 9" with self adjusters and E brakes. I was finally healthy enough to work on it but when I popped the drums well parts fell out, so I'm screwed up somewhere. Which is very typical for Me,but It feels good to get my hands dirty again.
Received 4,132 Likes
on
My apologies to Jim and Cougar. I will, if I can, delete my P poor posts.
Thanks' guys. After reading many threads spanning over a decade, it became apparent that there was some confusion over this issue. There was definitely confusion on my end. I just ordered a new drum to replace the new drum I sacrificed in the name of learning the hard way. "ANY HOO" I always appreciate the quick help that I always get rite here on FTE. Rockin on slow but sure, have a great weekend everyone.
if you look from the rear of the picture, then you'd have the driver's side view.
it is all in the arrows.
Leading Shoe vs Trailing Shoe Performance
Correct. This is because, when stopping with the truck moving forward, the primary shoe is self-energizing while the trailing shoe is self-disengaging. Since both have the stationary pivot at the bottom, the primary shoe leading edge contacts the drum first while the trailing shoe trailing edge makes initial contact. Thus the braking action on the primary shoe tends to pull it tighter into engagement, while the trailing shoe does the opposite. The trailing shoe has more braking surface to try to equalize the braking effort on both shoes. This is true for all single dual piston wheel cylinder designs.
