Crazy Problem
Old Aug 2, 2018 | 12:37 AM
rapracing's Avatar
rapracing
Crazy Problem
I came home tonight and stopped at the mailbox. I turned on the dome light on my side and go the mail. Turned it off and backed up the driveway. When I turned the truck off and opened the door the radio kept going and then the lights would not go out. I had no controls, it seemed everything was frozen. No hi lo beam switch, no 4 way, I could do nothing with the radio. Seemed like I had low beams. I messed for a while and finally disconnected the battery. That seemed to take care of all of the problems I was having but now the "check engine light" is on. Any ideas?
Old Aug 2, 2018 | 01:00 AM
ctimrun's Avatar
ctimrun
My 2016 F150 did just about this exact thing one time, except for the check engine light. Disconnected and reconnected the battery and it never did it again. I never even took it in to be checked out because I figured I would just get the deer in the headlights look from the service writer. I guess you’re lucky you have a check engine light, there should be a code to point them in the right direction to get it fixed.
radical_reabster
Aug 31, 2017 04:10 AM
dionisi58
Mar 3, 2010 02:54 PM
Metiphisto
Escape & Escape Hybrid
Nov 13, 2007 05:24 PM
dylexic_furby
Bronco II
Sep 16, 2003 11:22 PM
kris87bronco2
Bronco II
Jul 5, 2002 11:21 PM
