Mercon V
Old Jul 31, 2018 | 07:12 PM
dybeepvw's Avatar
dybeepvw
Mercon V
My daughters 1996 Explorer XLT,4.0L, 4x4 automatic, 183,000 miles, still looks almost new and has original drive train and runs great. I changed tranny fluid like 7 years ago and installed tranny cooler at that time, can't remember if it calls for Mercon V, or Mercon/Dexron III or not; going to change soon so "help". Its build date is May 1996. Thanks for any help
Old Aug 1, 2018 | 06:54 AM
shorod's Avatar
shorod
The factory service manual for the 2006 Explorer with 4R70W transmission calls for 13.9 quarts of MERCON® Multi-Purpose Automatic Transmission Fluid XT-2-QDX or equivalent MERCON® approved fluid. The owner's manual, assuming your daughter has that with the truck, should also list the recommended fluid type.
-Rod
Old Aug 1, 2018 | 09:28 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
MERCON is no longer produced. MERCON V was changed in 2006 to be compatible with older vehicles that required MERCON. MERCON V is now the proper fluid to use.
Old Aug 1, 2018 | 10:32 AM
dybeepvw's Avatar
dybeepvw
Ok, thanks Mark, that clears it up.
Stone Mathews
Jan 2, 2013 07:07 PM
kevin.ford-trucks
Mar 22, 2012 06:56 PM
ftowelding
Mar 3, 2012 09:49 AM
Whitey Ford
Feb 5, 2012 02:18 PM
EMC V10 X
Jan 21, 2011 09:59 AM
