Locking hubs stuck, help!
Old Jul 31, 2018 | 12:21 PM
04v10's Avatar
04v10
Hey all, first post here. I just bought a 2004 excursion 4x4 with the v10, and I can't get the front hubs to move at all by hand. What is the best way to loosen them up so I can use then until i can buy new hubs?
Thanks
Old Jul 31, 2018 | 01:02 PM
inthedirt's Avatar
inthedirt
I put a set of channel locks on mine to turn and that only lasted about 2 uses and promptly cracked all the plastic. OEM is pricey, as are replacements from Warn or Superwinch (can't remember all the options). If you can take them apart to service them, it's recommended and detailed instructions can be found in the sticky section above. I opted for a new replacement from Amazon for about $89 each. Work just as good as a factory unit so that I can maintain SOTF or fully manual.
Old Jul 31, 2018 | 01:04 PM
seville009's Avatar
seville009
You mean you can’t turn them between manual and auto? if so, since you’re going to replace them, soak them liberally with PB Blaster for a day then use pliers to try to turn them.
The proper methed would be to pull them out, clean them up, then grease them.
Old Jul 31, 2018 | 01:19 PM
04v10's Avatar
04v10
Thanks for the reply, where should i spray? I'm just getting into trucks and I'm not sure.
Thanks
Last edited by 04v10; Jul 31, 2018 at 02:04 PM. Reason: trying to delete this idk how lmao
Old Jul 31, 2018 | 01:20 PM
04v10's Avatar
04v10
Thanks
Old Jul 31, 2018 | 02:11 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I doubt you are going to fix them by just spraying they, maybe if you took them off and submerged them in pb blaster but at that point you might as well take them apart and clean them correctly.
plenty of video online if you need step by step instruction
Old Jul 31, 2018 | 03:35 PM
thor363's Avatar
thor363
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Jul 31, 2018 | 03:43 PM
seville009's Avatar
seville009
Thanks
all around the edge of the part of the hub the you turn.
Old Jul 31, 2018 | 06:02 PM
DavenTn's Avatar
DavenTn
They all stick.... eventually. They need to be 'serviced" occasionally. Once off, cleaned and loosened up, I soaked mine in Mobil 680 https://www.mobil.com/en/industrial/...l-shc-gear-680
Old Jul 31, 2018 | 06:19 PM
housedad's Avatar
housedad
13 years and 100,000 miles and mine still turn smooth and easy. I spray them in the crevice line with wd 40 once a year, exercise them well after lube, and then turn them back and forth once a month. I hope it lasts.
Old Aug 1, 2018 | 12:05 PM
Stewart_H's Avatar
Stewart_H
Thanks
Please see the tech folder. You'll find instructions there. Just scroll down to the Axles, Hubs, Ball Joints section and you'll see a couple threads addressing frozen hubs.
Stewart
davidstereo
Jul 21, 2013 03:11 PM
lifted77f250
Jan 2, 2009 01:10 AM
zack7.3
Mar 9, 2008 06:15 PM
fvm705
Nov 30, 2006 06:04 PM
Ilikemyfords
Jan 21, 2004 01:40 PM
