Hubs acting up?
Old Jul 20, 2013 | 08:24 PM
davidstereo's Avatar
davidstereo
Hubs acting up?
I tried to use 4x4 last weekend and got stuck at the farm. The manual hubs wouldn't budge either. I tried a small pair of pliers on it but didnt want to break the plastic switch on the hubs. After getting the tractor to pull it out I put it on the lift and the front drive shaft spins while in 4x4but does not engage the hubs. While the x was in the air I got a better pair of pliers to turn the manual hubs to lock. It was really hard to turn but it did. Now the 4x4 worked when I selected it inside. I see in the manual every 60k the needle bearing needs to be greased. Also, read up on that so more than likely it has never been done. Do I need new hubs to fix this? Any help would be great. Thanks, Dave
Old Jul 20, 2013 | 09:40 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Usually a tear down, good cleaning, re-lube and re-assemble will fix this problem.
Old Jul 20, 2013 | 11:33 PM
EXv10's Avatar
EXv10
Take those hubs off, drill a little hole next to the dial center rib, and soak them in a bowl of atf overnight. Also you can replace the o-rings in them.
Old Jul 21, 2013 | 10:08 AM
jayjjcc's Avatar
jayjjcc
Um... I'd clean and re-grease them the ATF soak sounds messy...
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Did it to mine, they turn easy as pie now...
Old Jul 21, 2013 | 01:22 PM
EXv10's Avatar
EXv10
Just for the dial end of it. You greased the dial?
Old Jul 21, 2013 | 03:01 PM
jayjjcc's Avatar
jayjjcc
I cleaned and re-greased the whole thing... sometimes proper maintenance is better than just always soaking parts overnight...
Old Jul 21, 2013 | 03:11 PM
EXv10's Avatar
EXv10
Just the dial part. You can clean and lube it all day but it has no effect on a sticking dial..............we're not talking grease here.
bkeese
Oct 23, 2014 01:47 AM
jlstorm
Dec 22, 2008 12:33 PM
live2hunt
1983 - 2012 Ranger & B-Series
Feb 6, 2007 04:32 PM
Ilikemyfords
Jan 21, 2004 01:40 PM
Wolfman2405
Offroad & 4x4
Aug 31, 2003 09:11 AM
