Gooseneck Hitch Question
Old Jul 30, 2018 | 05:49 PM
sdenn's Avatar
sdenn
Is the 2019 F350 hitch/ball on the OEM order 15J a hideaway type so that the bed can be as flat as possible?
Thanks for the info.
Old Jul 30, 2018 | 06:15 PM
Flyct's Avatar
Flyct
FTE Community Team
It’s identical to the Reese kit. https://www.etrailer.com/Gooseneck/Reese/RP30137.html
The Ball and chain link loops are removable and a cap fits over the holes when the hall is removed to keep the bed flat.
Watch the short video on the etrailer link above. The only difference is that the Ford kit has a different storage case but the ball and chain loops are identical.
Old Jul 30, 2018 | 06:22 PM
mhoefer's Avatar
mhoefer
You might find this thread interesting (https://www.ford-trucks.com/forums/1...on-a-17-a.html) , good pictures and discussion on the Anderson Ultimate which uses the gooseneck hitch to a Fiver, or there are examples converting a fiver to goose, with the safety chains within. You need both gooseneck prep and fifth wheel prep kits to be able to do the gooseneck towing, as you have the ball inserted in the bed, and two fiver pin points for the safety chains.
Old Jul 30, 2018 | 07:50 PM
sdenn's Avatar
sdenn
thank you both, exactly what I needed
Old Jul 30, 2018 | 07:57 PM
sdenn's Avatar
sdenn
Only thing I saw (on the video), is it looks awfully messy, don't know about you but my ball is covered in grease - don't know how this is going to work!!
Old Jul 30, 2018 | 08:27 PM
Xwild's Avatar
Xwild
the gooseneck kit puts 5 holes in your bed. 1 for the ball, and 4 for safety chain points (of which you use 2, unless you have a 450 and that fancy doodad it comes with)
. so don't order the fiver kit if you don't need a fiver kit..
I don't bother keeping a ton of grease on my ball.. just a light coat.. you get a little grease on you, but not much.. i normally have a rag handy to use for grabbing the ball.
Old Jul 30, 2018 | 09:11 PM
mhoefer's Avatar
mhoefer
I would still recommend the ordering of both prep kits, fifth and goose, for the simple flexibility of both types of hitches. Yes, you can convert any fiver to goose, or use the Anderson ultimate, but this gives you the best flexibility for a few hundred bucks.
Old Jul 30, 2018 | 09:21 PM
Brother_Bluto's Avatar
Brother_Bluto
The Fifth Wheel/Gooseneck prep package puts 5 holes in the bed (it isn't two separate options) You put the gooseneck ball in as needed - bed is flat when not needed. Instead of buying the Ford/Reese Goosneck hitch kit (which is the ball)... take a good look at the B&W gooseneck ball for the ford prep kit. Better built IMO.
rbrockman
All Things Towing
May 6, 2017 03:42 PM
lhansman
6.7L Power Stroke Diesel
Feb 11, 2015 11:47 PM
JesseFixesCATs
Jul 26, 2014 12:07 PM
Stewart_H
All Things Towing
Nov 18, 2008 02:51 AM
HOGman1024
May 21, 2006 11:54 PM
