Sponsored by: Real Truck
hidden ball hitch
Old Jul 10, 2014 | 12:06 PM
JesseFixesCATs's Avatar
JesseFixesCATs
hidden ball hitch
Anybody know of a good company to get a hidden ball hitch for gooseneck trailers for a 2012 f250 diesel fx4 short bed. Im needing the whole mounting kit. Ive already looked under the truck and its got a hole in the middle of the bed for it under the bed liner.
Thanks.
Old Jul 10, 2014 | 01:28 PM
phillips91's Avatar
phillips91
B&w, Reese, drawtite, hidden hitch or turnover ball would have what you are looking for.
Old Jul 10, 2014 | 01:41 PM
Desert Don's Avatar
Desert Don
All of the above are reputable companies.
I am personally using the B&W turnover ball with their 5th wheel companion hitch.
Old Jul 10, 2014 | 02:33 PM
JesseFixesCATs
Thanks guys ill look in to those
Old Jul 10, 2014 | 04:27 PM
1120MS's Avatar
1120MS
Thanks for this info ... this is in my list of to do's for my F350 and this post saves me time in researching.
Old Jul 10, 2014 | 06:39 PM
iamrfixit's Avatar
iamrfixit
B&W turnover ball, look no further.
Been using this hitch for 10 or 12 years, it's pulled some huge loads and continues to do so. I have zero complaints, my best friend liked it so much he has had one in all 6 of his trucks and uses them commercially running far more miles with a trailer than he does without. This hitch has almost become the standard that the others get judged by.
Old Jul 11, 2014 | 11:04 PM
1120MS's Avatar
1120MS
What model#'s are you using for the B&W turnover ball and 5th wheel companion? Thanks ...
Old Jul 26, 2014 | 12:07 PM
FERdter's Avatar
FERdter
B&W Turnover Ball Issue
On my 2007 F350 Diesel the B&W was there when I purchased the truck.
It has the F X 4 off road package and had standard shocks & 3" lift.
I switched to Rancho 9000 and with about a 1500 Lb load the B&W hitch mount dented the staggered shock on the passengers side. Luckily it didn't puncture the shock but there is a pretty good dent just below where the tube tapers out from the piston shaft.
My fix was to use a 3" cut off wheel on a die grinder and remove about 1/4" of the sharp corner on the frame mount of the B&W bracket.
I don't use the Flip ball hitch so I'm not worried about any minor loss in the mounting strength.
Just for your info.
Richard
rbrockman
All Things Towing
May 6, 2017 03:42 PM
WilliesSD250
Alaska Chapter
Jul 23, 2009 10:44 AM
Stewart_H
All Things Towing
Nov 18, 2008 02:51 AM
97 HD
Sep 3, 2007 08:53 PM
HOGman1024
May 21, 2006 11:54 PM
