Tedrob
Old Jul 29, 2018 | 12:57 PM
tedrob1950's Avatar
tedrob1950
Angry Tedrob
I hope someone can help me get my Class A motorhome running. It is a 1992 460 cu.in. fuel injected powertrain used to run great last year then quit. I have no spark and only fuel pressure when I power up the pump manually it sits at 40 psi. So far I have replaced the coil, ignition module, and distributor pick up. Still no spark, I have voltage at the coil, module, injectors, eec relay, but no power to the fuel pump relay trigger wire from the computer. I have checked for live battery power and ignition power at the computer both there. All fuses and links good. I am not sure where to go from here, anybody out there have any ideas for me. Need to get it running before the summer is over. Ted.
Old Jul 29, 2018 | 10:57 PM
mark a.'s Avatar
mark a.
Did you get the computer tested ? If not I would take or send it out to someone who can test it.
Edward Michael
18
Jul 24, 2019 09:40 PM
satguy1
Apr 2, 2010 08:08 AM
KEO
Nov 11, 2009 03:29 PM
bigbradleyp
Feb 27, 2007 12:00 PM
BRX98GT
1983 - 2012 Ranger & B-Series
Sep 10, 2004 08:38 PM
