275/65/18 Towing Tire Presures
2018 F150 3.5L Ecoboost SuperCrew 157" Max Tow with the factory 18" wheels. Door sticker is 1857# payload at 35 psi. Travel trailer being towed is 5500# and 800# tongue weight via Cat scale. All #'s work out within spec when fully loaded and ready to go.
I just towed 800 miles last weekend with the truck tires at 35 psi. Throughout the trip, the highest buildup I noticed was to 39 psi in the rears and 38 in the fronts while towing in 80 degree weather. No issues on the trip.
About to leave on a 2000+ mile round trip towing down south to Florida and back. Your opinion, stay at the 35 psi or inflate to the 44psi sidewall max cold on the factory Michelin Primacy XC 275/65/18's and why? I have always followed door sticker inflation data on my other trucks, but I've stumbled across a couple of articles suggesting running the max 44 psi on these P-Metric tires.
Thanks in advance.
Thanks in advance.
I concur. When the tires heat up, the pressure will increase 3 or 4 PSI. So inflating them to 40 PSI will give you a stiffer sidewalls, but should also reduce the heat build up. So you may end up with around 43 PSI once they're hot. If you start with 44 PSI, the warm up will go over the max.
I must be way off .... Mine are at 50psi all the time...never had a problem with any tires on my last 4 Ford trucks. Towing, town or cross country. I have them rotated with every OC and get 50k miles out of them. This is the first set of Hankooks so I'll see how they do. I have a temp gun and check them on the road..if 55 I leave them there.
SoCal69
01-07-2024 02:35 PM
Cudighi
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
08-11-2004 02:41 AM
