Sponsored by: Real Truck
tire PSI question
Old Oct 2, 2007 | 08:21 AM
///M Puller's Avatar
///M Puller
tire PSI question
I have the stock 17" on my 06 psd. Wife tows GN horse trailer (~8000 lbs) 2-3 times a week and I tow the open racecar trailer (~6000lbs) once a month. I also use it as a daily driver which is 75 miles each day, mainly highway.
I check the pressures and they are approximately 54 psi hot. I have read on here that some guys are running with 70 psi which I would assume is for heavy towing. What is a good average PSI to run? I do not want to change everytime I tow.
thanks,
Old Oct 2, 2007 | 10:22 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
What does the decal on the door jam tell you ? My '05 CC says 70psi all the time.
Old Oct 2, 2007 | 10:30 AM
yamaguy's Avatar
yamaguy
You should always run the pressure on the decal on the dor jam. Yeah it may ride a little softer with lower pressure, but it seem like the poeple who run lower pressure are the ones complaining about there tires not lasting very long. I always run 80psi all around and my BFG AT's last for 75k to 90k period. People don't beleive me, but they do!
Old Oct 2, 2007 | 10:37 AM
///M Puller
hmm, I checked the door sticker before and for some reason I thought that was for max. load, I guess not. It states 75 psi btw. I guess I will be getting some air over lunch
Old Oct 2, 2007 | 10:39 AM
arno's Avatar
arno
05 CC and mine says 75 as well. The ride is bouncy when empty. I have them at 70.
Old Oct 2, 2007 | 05:01 PM
chuck06250's Avatar
chuck06250
That's 75 psi COLD. If you were at 54 psi hot, you were asking for trouble!
