Speedometer Bouncing Question
Old Jul 26, 2018 | 02:52 PM
thatsneakyYeti's Avatar
thatsneakyYeti
In my 2003 Excursion (2wd, 6.0l), the speedometer started bouncing after I completed installation of the new FICM. The Vehicle Speed Sensor (VSS) is reading fine, verified through the OBD port. The issue only happens when moving, and seems to get worse if when the accelerator is pushed. It is not a constant or consistent bounce. I had the Speedometer/Instrument cluster checked though Circuit Board Medics, and it checked out fine. So I think there is a wire chaffed somewhere that is causing this. Any post I've searched online usually are from Super Duties, and most talk about the VSS. Does anyone have any ideas for where to check for a bare/broken wire that could be causing this? I'm not looking forward to starting from scratch, so I'm hoping someone has had this or "knew a guy that knew a guy." Thanks guys!
Old Jul 26, 2018 | 04:22 PM
wpnaes's Avatar
wpnaes
Like this?
Old Jul 26, 2018 | 05:29 PM
thatsneakyYeti
Originally Posted by wpnaes
Yes, very similar to that. It’s hard to say how fast they are going, but mine will climb as the truck goes faster. It just bounces10mph or so in either direction.
Old Jul 26, 2018 | 07:06 PM
wpnaes's Avatar
wpnaes
Not sure if this will be helpful, but it fixed my issue (in rainy conditions with the 6.8l).
https://www.ford-trucks.com/forums/1...l#post16884895
captain1997
1997 - 2003 F150
Nov 27, 2015 11:01 AM
kswebb1
Dec 21, 2009 04:07 PM
06SUPERDTY5.4
Mar 5, 2008 08:09 AM
akmud
1978 - 1996 Big Bronco
Jan 17, 2006 09:46 AM
