A/C and Condenser Mounting '55' F100
After this year’s hot and humid summer in the Midwest, I’ve decided to add A/C to my 1955 F100. I like my stock heater so have decided to go with an under dash unit. At this point I like the Nostalgic air UD-110 as its only 10” deep so can be installed flush with the dash. Has anyone used this unit or found others that are not too deep? My main question is about mounting the condenser. The radiator support saddle in my truck has a steel rod cross-brace that sits about 1” from the face of the radiator. I have seen some older posts that suggested cutting out the cross-brace in order to mount the condenser closer to the radiator, but I would prefer not to. I would love to get some opinions on what other have done to mount their condensers. I am using a 16” electric fan on my radiator (stock) and have no issues with cooling even at 95 degrees idle. Here are a couple options I’ve considered:1. Mount in front of the cross -brace and use a pusher fan ( would be a couple inches from radiator)2. Use a shim/ spacer on the radiator mounting points to move radiator closer to engine and then have room to mount condenser between the radiator and cross-brace3. Mount to cross-brace itself - not sure how secure this would be and still might be too far from radiator.Thanks for any suggestions ,
Brian
Brian
Received 4,132 Likes
on
There seems to be several different radiator saddles. I have at least 3 different ones. I believe The 53 saddles didn’t have the cross bracing but apparently spread enough to damage radiators so Ford added the cross braces. Don’t remove them. I did and destroyed an original radiator in short order. Maybe someone (number dummy) can give you the differences in saddles but some have a piece of angle moving the top of the radiator deeper in the saddle. If you have this type I’m pretty sure you won’t be able to sandwich a condenser between the radiator & cross bracing.
on
Thanks for the replies. Most of the instructions I've read for A/C installation suggest being as close to the radiator as possible and no more that one inch away. Looks like I will be around 1.5 inch away if I mount the condenser in front of the cross brace. Do you think I will need a condenser pusher fan? Thanks again.
on
Red Rascal
05-16-2018 02:13 PM
55forder
25
03-17-2005 11:46 AM
learpilot
12-17-2004 03:23 PM
55Bubba
02-19-2004 03:49 PM
