So i was curious just how strong a 400 crank is? I've heard that I can throw anything I want at it below 7000 and also heard don't push it past 600 hp. Well I intend to find out the level. But first this... Will the snout hold a blower drive? Starting at 2-3psi on a 11:1 bottom end
Reason: Typo
They are strong but use ARP bolts, heavy, long stroke engine not really intended for high RPM but with the right parts you can go there. 2/3 psi isn't much boost, not sure what you mean by 11:1
Oh I mean blower lol. I'm also considering going with the 408c scat 9000 crank with bearing spacers but idk how much stronger it is. I know it's high... I may be able to tweak it down to 10:1 but that'd be it. 700 already dropped on pistons before I fell into this blower deal.
(I'm picturing the first part of the film 'Mad Max' with the sweet sounding blower whine and the blower sticking out of the bonnet saying hello.)
An SCR of 10 might still be too high.
I had mentioned 9, but now i'm thinking 8.
Nothing wrong with Scat goodies, but best to check with them what their HP limit is.
I think their cranks are made of steel, as opposed to iron, or whatever the OE is made of, which allow for a lot more HP.
Although you've already spent $700 on pistons, don't build your motor around the pistons. Build the motor as a total package with each part complimenting the next.
E.G. Your existing SCR specs will determine the cam to be used which might not be the optimal cam.
I think you should do more homework on blower engine requirements.
Whatever you do, don't get a Scat catalogue. I got one, got addicted, and had to go to rehab. LOL
Find "optimal" boost of supercharger you want ro run on your engine (engine cubic inches and supercharger capacity), shoot for engine compression based ovn the middle of this range.... It isn't going to be 11:1!
You need to start doing some 9th grade math and figure out what your dynamic compression ratio is going to be. If it gets much over 8-1 you ain't going to be running pump gas in that thing. Of course you could burn alcohol and just drive it 1/4 mile at a time.
You should invest in a good set of rods. If there is a week link it's the factory rods. I don't care what you do to them or what bolts you put in them you will end up bending them. You need to get your compression down a lot to run that thing. The open chamber 4v heads, crappy as they are might be just what you need for a blower. With their big valves and huge ports it could move so much air that you should be able to avoid the stalling they suffer from, at least on the intake side. Maybe a good port job and a set of port stuffers might help out the exhaust side to where it's good enough. The big open chambers will also help get your compression down, with a set of flat tops you should be right about where you want to be on compression.
The DCR will definitely not be pump gas setup. Going alky for sure. wether its e85 or full methanol is still up in the air.
I already have open heads and flats. Still 11:1. Only rod option is Molnar technologies UNLESS I solve the forged 400 crank riddle with all Ford parts somehow
