Squeaky u-joint(s) help
Old Jul 26, 2018 | 07:57 AM
CelticOne's Avatar
CelticOne
Regular User
So Cletus has at least one squeaky u-joint.
The drive train is all 1975 F-100 2wd long box 302 3-on-the-tree. Two piece driveshaft so 4 u-joints, all non-greasable (no zerk fittings).
Any suggestions on how I could find the culprit(s)? Is there a relatively easy way to pack grease in these?
Thanks in advance.
Old Jul 26, 2018 | 08:00 AM
somethingclever's Avatar
somethingclever
Would suggest to just change them all.
One is dry....the others likely not far behind.
Old Jul 26, 2018 | 08:51 AM
beartracks's Avatar
beartracks
Maybe the center carrier bearing. "U" joints don't normall squeak.
Old Jul 26, 2018 | 03:02 PM
somethingclever
they can squeak when they are dry and in need of replacement
Old Jul 26, 2018 | 04:52 PM
jakeharp's Avatar
jakeharp
With the work needed to pull the caps and grease you could replace the U-Joint and give yourself a lot of cheap insurance in the same amount of time... At lest you dont have 8 to replace like us High Water owners .... had to say High Water... just had too...
Old Aug 25, 2018 | 04:35 PM
CelticOne's Avatar
CelticOne
Regular User
Just to follow up - 2 bad ujoints replaced. Squeak gone!
Old Aug 25, 2018 | 04:44 PM
72rtchallenger's Avatar
72rtchallenger
I would find a one piece drive shaft and do away with that carrier bearing setup , if you can source one ,
Gwilkrrs
6.4L Power Stroke Diesel
Jun 27, 2016 10:21 PM
powerstroker100
27
Jul 30, 2010 06:10 PM
HareBall
May 30, 2007 08:10 PM
Keepin It Real
Apr 9, 2007 06:21 PM
comic75
Apr 28, 2003 10:16 AM
