I have a 99' 150 xlt 4*4 ex cab, I have rebuilt or replaced pretty much everything with OEM or better, i don't think I need to list everything I've done. It's a dd and I bought it with the intention of keeping and having as a permanent truck because i like this generation and it served my needs, well, I've ended up needing a 250 so I found a 00' pretty much cream puff and going to make it mine as i did with the 150.
I don't expect to get my money back on the 150 but I do think it has value above the going rate of 2500 or less.
One last thing, the engine is 5.4 215k and doesn't use oil between 3k changes starts zero issues. front differential is original but no problems.i know I'm not giving a lot of information I have more to share if interested .
Anyway, with this information,
Where should I be price wise.
Thanks, you can be as critical as you like.
