blower motor not operating
Old Jul 24, 2018 | 09:41 AM
joeboy51's Avatar
joeboy51
I have a 1976 f150 with factory air. The blower motor is not functioning. There is power at the fuse block but no power at the fan switch. I have checked the blower resistor and it is ok. Where to check now?
Old Jul 24, 2018 | 11:17 AM
72rtchallenger's Avatar
72rtchallenger
You can check the fan switch on dash , has it got power an working ?
Old Jul 24, 2018 | 04:08 PM
dlburch's Avatar
dlburch
after the fuse, power goes through the AC mode switch, when it is on a fan relay is powered sending power to the fan switch...the problem is probably in one of those 2 places assuming your wiring is in good shape...
Old Jul 25, 2018 | 09:16 AM
joeboy51's Avatar
joeboy51
There is no power at the ac mode switch connector
Old Jul 25, 2018 | 09:26 AM
joeboy51's Avatar
joeboy51
Sorry, I forgot to have ignition on when testing.There is power at the ac mode switch connector but not at the fan speed switch.
Old Jul 25, 2018 | 11:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's also the blower motor resistor, shown as 19706 in pic.
Old Jul 25, 2018 | 12:11 PM
dlburch's Avatar
dlburch
assuming power is making it through that switch, you should have power on the yellow wire...this wire should go to the relay which (if working) will provide power the the fan switch and one side of the blower motor resistor...
Old Jul 25, 2018 | 03:13 PM
jakeharp's Avatar
jakeharp
When my resistor was blown only the highest fan setting would work, after new resistor all speeds worked..
Old Aug 15, 2018 | 11:31 PM
CharlieXLT's Avatar
CharlieXLT
I had the same problem today. Blower motor just quit. No warning... just stopped. After tracing and checking voltages, I found no power to the fan switch, and after more tracing, I found that relay switch under the dash near the glove box. Turned out to be no bueno! Just to verify, I jumped the terminals on the relay and the fan started up and ran on all speeds. Got a new blower relay on it's way to the local Oreilly's ($13)... should be here by 3 tomorrow. I love the fact that they actually put that thing in a really easy spot to change!
Funny thing was... in my Ford Shop Manual... there's a flow chart for troubleshooting the blower motor. It says nothing about checking the relay!
Old Aug 16, 2018 | 09:49 AM
dlburch's Avatar
dlburch
I think that relay was only used for a short time, possibly 1976 only.
ssj7kids
Sep 26, 2011 12:59 AM
tim nick
Escape & Escape Hybrid
May 25, 2011 10:34 PM
Highboy74
Apr 13, 2011 11:13 PM
sparkieg
Nov 28, 2008 10:35 AM
Izzy
1983 - 2012 Ranger & B-Series
17
Dec 5, 2003 01:58 PM
