Passenger Window Motor/Switch Issues
Old Jul 23, 2018 | 07:25 PM
SmackDaddy's Avatar
SmackDaddy
My passenger front window rolled up one day and just stopped working so I bought a replacement OEM motor. I removed the old motor and tested it with the passenger switch and it rolls up but not down and the driver master switch will not move it at all. Same with the new motor plugged in. This seems like a wiring issue to me. What’s the general consensus?
Old Jul 24, 2018 | 12:51 PM
dangrus's Avatar
dangrus
Check the wiring in the hinge area of the Pass and Driver's door. The Passenger switch slaves off of the Driver so a break in either one will cause that issue. I usually have to scab in a wire from under the dash into the door.
Old Jul 24, 2018 | 02:32 PM
SmackDaddy's Avatar
SmackDaddy
Thanks I will check that, figured it would probably be a bad wire.
AKHunter93
Aug 7, 2016 02:30 PM
pathfindertango
Feb 20, 2015 01:20 PM
waskin27
Sep 7, 2012 07:30 PM
tanktopsntoolbelts
Apr 30, 2012 07:52 PM
EdJones
Sep 4, 2011 09:33 PM
